05-26-2022
01:05 PM
- Mute
- Permalink
- Report
05-26-2022
01:05 PM
I am afraid, I cannot compile your sources without all the necessary libraries. Instead, what I would recommend is try to debug it yourself and see where its hanging?
1. First, try to see if you can translate using a local machine and measure the speed
2. If it works fine BUT translating it off a network is slow, then its most likely related to network issues
3. If local machine translation is slow, then you would need to debug it line by line and see where its taking up time
4. You could also try manually translating it using Inventor and see if that takes time.
The sample part file you enclosed seems straightforward and exports to step very fast.
-shiva
Shiva Sundaram
Inventor Development
