Michael.Navara
in reply to: RNDinov8r
If you use VB.Net for addin, you can use System.IO.Path and its funckionality instead of direct string manipulation
Dim asmFullFileName As String '= ThisDoc.Document.FullFileName ' FOR iLogic TEST ONLY
Dim sPartsListPath = IO.Path.GetDirectoryName(asmFullFileName)
