05-24-2022
11:00 AM
- Mute
- Permalink
- Report
05-24-2022
11:00 AM
Hi @ABHUT_9090. I created something that you may be able to use.
Sub Main
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
MsgBox("An Assembly Document must be active for this rule to work. Exiting.", vbCritical, "")
Exit Sub
End If
Dim oADoc As AssemblyDocument = ThisDoc.Document
Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
Dim oBOM As BOM = oADef.BOM
If Not oBOM.StructuredViewEnabled Then oBOM.StructuredViewEnabled = True
If oBOM.StructuredViewFirstLevelOnly Then oBOM.StructuredViewFirstLevelOnly = False
Dim oBOMView As BOMView = oBOM.BOMViews.Item("Structured")
For Each oRow As BOMRow In oBOMView.BOMRows
Dim oRowDoc As Document = Nothing
Try
oRowDoc = oRow.ComponentDefinitions.Item(1).Document
Catch
Continue For 'skip to next BOMRow
End Try
If IsNothing(oRowDoc) Then Continue For
Dim oPartLength As Double = 0.0
Dim oCProps As PropertySet = oRowDoc.PropertySets.Item("Inventor User Defined Properties")
Try
oPartLength = oCProps.Item("LENGTH").Value
Catch
End Try
If oPartLength = 0.0 Then Continue For 'skip to next BOMRow
Dim oQty As Integer = oRow.ItemQuantity
Dim oTotalLength As Double = (oPartLength * oQty)
'value may need to have units converted if not correct
Dim oTotalInchCProp As Inventor.Property = Nothing
Try
oTotalInchCProp = oCProps.Item("total inch")
oTotalInchCProp.Value = oTotalLength
Catch
oTotalInchCProp = oCProps.Add(oTotalLength, "total inch")
End Try
Next
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS)
If you want and have time, I would appreciate your Vote(s) for My IDEAS :bulb: or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
