WCrihfield
in reply to: ABHUT_9090
Hi @ABHUT_9090.  This seems like a fairly common type of request.  I'm pretty sure it can be accomplished.  What is the source for the information in those first two columns?  Do they both contain custom iProperties?  If one or both are one of the regular BOM quantity specifiers, which type?  There are several types of quantities involved in BOM's:  Unit Quantity, Base Quantity, Base Unit, Item Quantity (net/filtered), Total Quantity (gross/not filtered).  Do you plan on using a custom iProperty for column 3, or is it representing something else?  If that custom iProperty does not exist in every component document, then do you want it created within every unique document represented by those components?
Wesley Crihfield
(Not an Autodesk Employee)
