A.Acheson
in reply to: A.Acheson
For the VBA equivalent. Here is some reference information for the System Object to check if the folder exist in windows.  To make it easier I added the  reference to "Microsoft Scripting Runtime" under Tools>References. This article  shows how to do add this reference. Without this reference you will need to know the exact method rather than having full access to the list of methods available under the object.
Public Sub ExportiFactorytoDXF()
   Dim oDoc As PartDocument
   Set oDoc = ThisApplication.ActiveDocument
   Dim oDef As SheetMetalComponentDefinition
   Set oDef = oDoc.ComponentDefinition
    'Read the folder in Windows
    '*********************Early bindings*****************
    'Add reference to "Microsoft Scripting Runtime" under tools>References (https://wellsr.com/vba/2018/excel/introduction-to-the-vba-filesystemobject/)
    'Early bindings allows access to the object collection
    Dim fs As FileSystemObject
    Set fs = New FileSystemObject
     '******************Late bindings*********
    'Dim fs As Object
    'Set fs = CreateObject("Scripting.FileSystemObject")
     'Create the folder path
     Dim oPath As String
     oPath = fs.GetParentFolderName(oDoc.FullFileName) & "\DXF"
    'check if the folder exist and if not create
    If fs.FolderExists(oPath) = False Then
        fs.CreateFolder (oPath)
    End If
    Dim oRow As iPartTableRow
    For Each oRow In oDef.iPartFactory.TableRows
    'Change the member
    oDef.iPartFactory.DefaultRow = oRow
   ' MsgBox(oRow.MemberName, "Name of the Member")
    If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
        If oDef.HasFlatPattern = False Then
            oDef.Unfold
        Else
            oDef.FlatPattern.Edit
        End If
        Dim odxf, odxfname As String
        odxf = "FLAT PATTERN DXF?OuterProfileLayer=0&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=0&InteriorProfilesLayerColor=0;0;0&BendDownLayerLineType=37633&BendDownLayerColor=0;0;255&BendUpLayerLineType=37633&BendUpLayerColor=0;0;255IV_BEND;IV_BEND_DOWN;IV_OUTER_PROFILE;IV_INTERIOR_PROFILES;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_ROLL_TANGENT;IV_ROLL&InvisibleLayers=IV_TANGENT;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES" _
        + "&RebaseGeometry=True" _
        + "&SimplifySplines=True" _
        + "&SplineTolerance=0.01" _
        odxfname = oPath & "\" & oRow.MemberName & ".dxf"
        Call oDef.DataIO.WriteDataToFile(odxf, odxfname)
        oDef.FlatPattern.ExitEdit
        MsgBox ("DXF has been saved in this location: " + odxfname)
    Else
        MsgBox ("There must be a sheetmetal component to get the dxf file!")
    End If
Next
End Sub
Regards
Alan
