A.Acheson
in reply to: bionorica2015
The original ilogic rule works . There was some feature looping which is likely not being used  so I removed that. Are you running this rule in the factory file?
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
Dim oPartMember As iPartMember
For Each oTab As iPartTableRow In oDef.iPartFactory.TableRows
	MessageBox.Show(oTab.MemberName, "Name of the Member")
	iPart.ChangeRow("", oTab.MemberName)
	If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
		If oDef.HasFlatPattern = False Then
			oDef.Unfold
		Else
			oDef.FlatPattern.Edit
		End If
		Dim odxf As String
		Dim oPath As String
		oPath = ThisDoc.Path & "\DXF"
		If Not System.IO.Directory.Exists(oPath) Then
			System.IO.Directory.CreateDirectory (oPath)
		End If
		Dim odxfname As String
		odxf = "FLAT PATTERN DXF?OuterProfileLayer=0&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=0&InteriorProfilesLayerColor=0;0;0&BendDownLayerLineType=37633&BendDownLayerColor=0;0;255&BendUpLayerLineType=37633&BendUpLayerColor=0;0;255IV_BEND;IV_BEND_DOWN;IV_OUTER_PROFILE;IV_INTERIOR_PROFILES;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_ROLL_TANGENT;IV_ROLL&InvisibleLayers=IV_TANGENT;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES" _
		+ "&RebaseGeometry=True" _
		+ "&SimplifySplines=True" _
		+ "&SplineTolerance=0.01" _
		odxfname = oPath & "\" & oTab.MemberName & ".dxf"
		oDef.DataIO.WriteDataToFile(odxf, odxfname)
		oDef.FlatPattern.ExitEdit
		MessageBox.Show ("DXF has been saved in this location: " + odxfname)
	Else
		MessageBox.Show ("There must be a sheetmetal component to get the dxf file!")
	End If
Next
 The VBA equivalent will take a lot of rework to remove System.IO reference and ilogic member change.
Regards
Alan
