05-17-2022
11:04 AM
- Mute
- Permalink
- Report
05-17-2022
11:04 AM
Hi @koenroovers. I assume that by "group the assemblies" that are the same but on different lines you mean combine their quantities into one line, then get rid of the other row (or all other rows), not just move the rows to be next to each other. So, I think I have some more advanced iLogic code that may accomplish that task for you, but I haven't tested it yet myself. You can give this rule a try if you want.
Sub Main
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oPartList As PartsList = oDrawDoc.ActiveSheet.PartsLists.Item(1)
Dim oUniquePNRows As New Dictionary(Of String, PartsListRow)
'get Part Number column
Dim oPNCol As PartsListColumn = GetPartNumberColumn(oPartList)
If IsNothing(oPNCol) Then
MsgBox("Part Number Column Not Found.", vbExclamation, "")
Exit Sub
End If
'get Quantity column
Dim oQtyCol As PartsListColumn = GetQuantityColumn(oPartList)
If IsNothing(oQtyCol) Then
MsgBox("Quantity Column Not Found.", vbExclamation, "")
Exit Sub
End If
For Each oRow As PartsListRow In oPartList.PartsListRows
Dim oPN As String = oRow.Item(oPNCol).Value 'Part Number
If oPN.Contains("WA") Then
oRow.Visible = True
Else
oRow.Visible = False
End If
If Not oUniquePNRows.ContainsKey(oPN) Then
oUniquePNRows.Add(oPN, oRow)
Else
'the Dictionary already contains a 'Row' with that Part Number
'so, value is not unique, so combine its quantity with
'previous row that had same cell value, then hide this row
'first get previous row with this cell value
oPreviousRow = oUniquePNRows.Item(oPN)
Dim oPreviousRowQuantity As Integer = CInt(oPreviousRow.Item(oQtyCol).Value)
Dim oThisRowQuantity As Integer = CInt(oRow.Item(oQtyCol).Value)
oPreviousRow.Item(oQtyCol).Value = (oPreviousRowQuantity + oThisRowQuantity).ToString
'oRow.Remove 'only works for custom rows
End If
Next
End Sub
Function GetPartNumberColumn(oPList As PartsList) As PartsListColumn
If IsNothing(oPList) OrElse oPList.PartsListColumns.Count = 0 Then Return Nothing
For Each oCol As PartsListColumn In oPList.PartsListColumns
If oCol.PropertyType = PropertyTypeEnum.kFileProperty Then
Dim oPropSetID As String
Dim oPropID As Integer
oCol.GetFilePropertyId(oPropSetID, oPropID)
If oPropSetID = "{32853F0F-3444-11d1-9E93-0060B03C1CA6}" And _
oPropID = 5 Then
Return oCol
End If
End If
Next
Return Nothing
End Function
Function GetQuantityColumn(oPList As PartsList) As PartsListColumn
If oCol.PropertyType = PropertyTypeEnum.kQuantityPartsListProperty Then
Return oCol
End If
Next
Return Nothing
End Function
Wesley Crihfield
(Not an Autodesk Employee)
