WCrihfield
in reply to: frank_schalla
Hi @frank_schalla.  You may have to share a lot more details than that so we can better understand the situation and offer better solutions.  Are you looking for an iLogic rule based solution?  If so, will it be ran on an active part document, an assembly document, or a drawing document?  Are the parts in question all going to be sheet metal parts, or are they just regular parts, or are some regular parts and some sheet metal parts?  Will all the parts be one of the 3 listed shapes (square, rectangle, or round), or are some other shapes?  What type of feedback or results are you expecting from the test (pop-up message, write something to an iProperty/Parameter, run a secondary process on it, etc.)?  If you wand to run a rule on an assembly, should it just work on the top level components, or should it dig down into sub assemblies, and should it process any of the sub assemblies themselves, or just the parts?
Wesley Crihfield
(Not an Autodesk Employee)
