Ralf_Krieg
in reply to: liminma8458
Hello
Since Inventor 2022 there are some improvements I found some days ago. You can create a ClientResourceMap and add the different Icons. There is also support for different themes included.
@basautomationservices
Sorry, found that a while after your threads. But I did not found a solution for transparancy problem somewhere in there.
Here's a small VBA sample demonstrating the core functionality. It assumes there are two bitmaps (16x16pixel) in C:\temp and the active theme in Inventor is the dark theme. Otherwise you need to adjust the code.
Select a part in your assembly and run the sample. This override works just for the node of the selected part. If you place another occurrence of the same part, the standard icons are displayed.
Sub modifyIcon()
Dim oApp As Application
Set oApp = ThisApplication
Dim oDoc As AssemblyDocument
Set oDoc = oApp.ActiveDocument
'Get the ClientResourceMap or create a new one
On Error Resume Next
Dim oClientResourceMap As ClientResourceMap
    Set oClientResourceMap = oApp.ClientResourceMaps.ItemById("MyTestResourceMap", 1)
If Err.Number <> 0 Then
    Set oClientResourceMap = oApp.ClientResourceMaps.Add("MyTestResourceMap", 1)
    Dim oIcon_1 As IPictureDisp
    Set oIcon_1 = stdole.LoadPicture("C:\temp\1.bmp")
    Dim oIcon_2 As IPictureDisp
    Set oIcon_2 = stdole.LoadPicture("C:\temp\1_gray.bmp")
    Dim oNVMap As NameValueMap
    Set oNVMap = oApp.TransientObjects.CreateNameValueMap
    Call oNVMap.Add("Icon1", oIcon_1)
    Call oNVMap.Add("Icon2", oIcon_2)
    Call oClientResourceMap.SetBrowserIconData(oNVMap, "DarkTheme", True)
End If
On Error GoTo 0
'Get the ClientNodeResource in the actvie BrowserPane or create it
Dim oBP As BrowserPane
Set oBP = oDoc.BrowserPanes.ActivePane
Dim oNode As BrowserNode
Set oNode = oBP.TopNode.BrowserNodes.Item(oBP.TopNode.BrowserNodes.count - 1)
Dim oCNRes As ClientNodeResource
Set oCNRes = oDoc.BrowserPanes.ClientNodeResources.ItemById("MyTestResourceMap", 1)
    Set oCNRes = oDoc.BrowserPanes.ClientNodeResources.AddNodeResource("MyTestResourceMap", 1, "Icon1")
End If
oCNRes.InvisibleIconName = "Icon2"
'assign the ClientNodeResource as Override to the selected Browsernode
Dim oBNDef As NativeBrowserNodeDefinition
Set oBNDef = oDoc.BrowserPanes.GetNativeBrowserNodeDefinition(oDoc.SelectSet(1))
oBNDef.OverrideIcon = oCNRes
oApp.ActiveView.Update
End Sub
R. Krieg
RKW Solutions
www.rkw-solutions.com
