donnie.morris
327 Views, 4 Replies
Assign iProperty from Drop down Box in Forms
Ok, I'm certain this is easy but it seems to be escaping me.
I have a user parameter that consist of a multi-value list. I need this value to assign to a custom iProperty when selected from a form.
I have the multi-value list created as well as the form but I can't make the form assign the vale once selected.
Example, "User Parameter" = Export Class
"Export Class" is selectable from drop down box, "Customer, Vendor, Shop, Default"
"Export Class" should be populated once value is selected by the drop down box.
Thanks in advance
blandb
in reply to: donnie.morris
Something like this:
MultiValue.SetList("Selector", "Customer", "Vendor", "Shop", "Default", "other")
Select Case Selector
Case "Customer"
	Parameter("user1") = "Export Class"
Case "Vendor"
Case "Shop"
Case "Default"
Case "other"
	Parameter("user1") = ""
End Select
Autodesk Certified Professional
donnie.morris
in reply to: blandb
Not quite what I'm looking for, maybe I didn't explain what I am looking for well.
Basically I have a form that looks like this:
I need the Export_Class drop down to assign the selection to a Custom iProperty called "Export Class:
A.Acheson
Unfortunately you cannot export a text parameter to an  iProperty. You will need to pass the parameter to the custom iProperty.
iProperties.Value("Custom", "Export_Class")= Export_Class
Regards
Alan
Figured it out, thanks for all the help.
oTrigger = Export_Class
InventorVb.DocumentUpdate()
iProperties.Value("Custom", "Export Class") = Export_Class
