Ralf_Krieg
in reply to: Nathan.r12345
Hello
Afaik not within an iLogic form.
Maybe it is possible to run a rule that creates a new undocked view of the current document and enter sketch edit mode. Then the rule opens your form and every changed parameter value in the form will change visible your sketch, if the parameter is used in a sketch dimension. The form should be shown modal, so the user can only interact within. The Close button of the form should call another rule, closing the view, update the model and activate the view shown before start.
R. Krieg
RKW Solutions
www.rkw-solutions.com
