you can check with the "before save event" what the PartNumber was
you can set with the "after save event" what the PartNumber must be.
I have this put into a small addin for inventor.
Send me a private message and I can give to you.
The addin prevents the partnumber from update on save and leaves the partnumber as it was before save.
Regards
Arthur Knoors
Autodesk Affiliations:
