04-16-2022
04:27 PM
- Mute
- Permalink
- Report
04-16-2022
04:27 PM
You can check the string value coming from the the input list box selection. Many ways to write this, check if it is Nothing, check if it has an empty string, or use the string function to return a boolean value.
If oSelSheetMaterialStockCodeOpt2 Is Nothing Then
MsgBox("Nothing Selected") Else MsgBox(oSelSheetMaterialStockCodeOpt1) End If
If oSelSheetMaterialStockCodeOpt1 = Nothing Then MsgBox("Nothing Selected")
Else
If oSelSheetMaterialStockCodeOpt1 = "" Then MsgBox("Nothing Selected")
Else
If String.IsNullOrEmpty(oSelSheetMaterialStockCodeOpt1) = True Then
String Check Code
Dim oDoc As Document = ThisDoc.Document Dim CustTypeALU As New ArrayList CustTypeALU.Add(".063, Sheet, Aluminum, 5052-H32, 60.00 x 120.00 | ME-CRS-0003") CustTypeALU.Add(".125, Sheet, Aluminum, 5052-H32, 60.00 x 120.00 | ME-CRS-0005") CustTypeALU.Add(".090, Sheet, Aluminum, 5052-H32, 60.00 x 120.00 | ME-CRS-0007") CustTypeALU.Add(".190, Sheet, Aluminum, 5052-H32, 60.00 x 120.00 | ME-CRS-0009") CustTypeALU.Add(".050, Sheet, Aluminum, 5052-H32, 60.00 x 120.00 | ME-CRS-0013") CustTypeALU.Add(".030, Sheet, Aluminum, 5052-H32, 60.00 x 120.00 | ME-CRS-0016") CustTypeALU.Add(".080, Sheet, Aluminum, 5052-H32, 60.00 x 120.00 | ME-CRS-0017") Dim oSelSheetMaterialStockCodeOpt1 As String = InputListBox("Select Sheet Material Stock Code", CustTypeALU, oSheetMaterialStockCodeOpt1, Title := "ALU Sheet Selection", _ ListName := "ALU Sheet Stock Code") If oSelSheetMaterialStockCodeOpt1 = Nothing Then 'can also use "" as an empty string instead of Nothing Else sSplit = Split(oSelSheetMaterialStockCodeOpt1, "|") oDesc = sSplit(0) oPN = sSplit(1) 'if this custom property doesn't exist, this next line will also create it if needed (no error shown) iProperties.Value("Custom", "Material Stock Code 1") = oPN MsgBox(iProperties.Value("Custom", "Material Stock Code 1") ) End If Dim CustTypeGALV As New ArrayList CustTypeGALV.Add("16GA, Sheet, Galvanneal Steel, 60.00 x 120.00 | ME-GALN-0001") CustTypeGALV.Add("18GA, Sheet, Galvanneal Steel, 60.00 x 120.00 | ME-GALN-0002") CustTypeGALV.Add("22GA, Sheet, Galvanneal Steel, 60.00 x 120.00 | ME-GALN-0003") CustTypeGALV.Add("14GA, Sheet, Galvanized Steel, 60.00 x 120.00 | ME-GALV-0001") CustTypeGALV.Add("16GA, Sheet, Galvanized Steel, 60.00 x 120.00 | ME-GALV-0002") CustTypeGALV.Add("18GA, Sheet, Galvanized Steel, 60.00 x 120.00 | ME-GALV-0003") CustTypeGALV.Add("24GA, Sheet, Galvanized Steel, 60.00 x 120.00 | ME-GALV-0004") Dim oSelSheetMaterialStockCodeOpt2 As String = InputListBox("Select Sheet Material Stock Code", CustTypeGALV, oSheetMaterialStockCodeOpt2, Title := "GALV Sheet Selection", _ ListName := "GALV Sheet Stock Code") If oSelSheetMaterialStockCodeOpt2 = Nothing Then Else sSplit = Split(oSelSheetMaterialStockCodeOpt2, "|") oDesc = sSplit(0) oPN = sSplit(1) 'if this custom property doesn't exist, this next line will also create it if needed (no error shown) iProperties.Value("Custom", "Material Stock Code 1") = oPN MsgBox(iProperties.Value("Custom", "Material Stock Code 1")) End If
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
Regards
Alan
