- Mute
- Permalink
- Report
'' Dim a As Inventor.ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("SheetMetalSetBodyRuleStyleCtxCmd")
Dim a As Inventor.ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("SheetMetalStylesCmd")
a.Execute
you mean on create new from template you need to see this box:
Let the above rule on new:
Arthur Knoors
Autodesk Affiliations:
