- Mute
- Permalink
- Report
Hi @antonio.silvaluna. Here is another version you can try that is similar to the last one I posted. But this version does not use the StandardObjectFactory route. Instead it uses the API route. I also combined the two Sub routines into one. That Sub routine might even be simplified even further since the 'test' version of SheetMetalStyle is always named exactly the same as the original, but with the " (Test)" at the end if its name. It might just be able to capture its current SheetMetalStyle name, check if it 'EndsWith' " (Test)", and if not, try to change it to the same name with that at the end of it. But I don't know if that would fit your more practical needs later. But since the other 'Test' version SheetMetalStyle might not exist, in order to avoid that potential error without making the code exponentially longer, I incorporated a Try...Catch statement, and put the main task inside of that. And since I don't know how many components you may be cycling through, in the Catch side I left the MsgBox commented out, and left the Logger line un-commented, to help it run more smoothly. You would then want to check your iLogicLog tab to see if it encountered any problems afterwards.
Sub Main()
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
MsgBox("An Assembly Document must be active for this rule to work. Exiting.", vbCritical, "")
Exit Sub
End If
Dim oADoc As AssemblyDocument = ThisDoc.Document
ChangeToTest(oADoc)
End Sub
Sub ChangeToTest(oADoc As AssemblyDocument)
For Each oOcc As ComponentOccurrence In oADoc.ComponentDefinition.Occurrences
If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
ChangeToTest(oOcc.Definition.Document)
End If
If Not TypeOf oOcc.Definition Is SheetMetalComponentDefinition Then Continue For
Dim oSMDef As SheetMetalComponentDefinition = oOcc.Definition
Dim ActiveStyle As SheetMetalStyle = oSMDef.ActiveSheetMetalStyle
'since the other named SheetMetalStyle may not exist, we will use a Try...Catch statement
Try
If ActiveStyle.Name = "10ga GA Brt" Then
oSMDef.SheetMetalStyles.Item("10ga GA Brt (Test)").Activate
ElseIf ActiveStyle.Name = "10ga GA Jkt" Then
oSMDef.SheetMetalStyles.Item("10ga GA Jkt (Test)").Activate
ElseIf ActiveStyle.Name = "10ga SS 304L Solid" Then
oSMDef.SheetMetalStyles.Item("10ga SS 304L Solid (Test)").Activate
ElseIf ActiveStyle.Name = "12ga GA Brt" Then
oSMDef.SheetMetalStyles.Item("12ga GA Brt (Test)").Activate
ElseIf ActiveStyle.Name = "12ga GA Jkt" Then
oSMDef.SheetMetalStyles.Item("12ga GA Jkt (Test)").Activate
ElseIf ActiveStyle.Name = "14ga GA Brt" Then
oSMDef.SheetMetalStyles.Item("14ga GA Brt (Test)").Activate
ElseIf ActiveStyle.Name = "14ga GA Jkt" Then
oSMDef.SheetMetalStyles.Item("14ga GA Jkt (Test)").Activate
ElseIf ActiveStyle.Name = "14ga SS 304L Solid" Then
oSMDef.SheetMetalStyles.Item("14ga SS 304L Solid (Test)").Activate
ElseIf ActiveStyle.Name = "16ga GA Brt" Then
oSMDef.SheetMetalStyles.Item("16ga GA Brt (Test)").Activate
ElseIf ActiveStyle.Name = "16ga GA Jkt" Then
oSMDef.SheetMetalStyles.Item("16ga GA Jkt (Test)").Activate
ElseIf ActiveStyle.Name = "16ga SS 304L Solid" Then
oSMDef.SheetMetalStyles.Item("16ga SS 304L Solid (Test)").Activate
ElseIf ActiveStyle.Name = "18ga GA Brt" Then
oSMDef.SheetMetalStyles.Item("18ga GA Brt (Test)").Activate
ElseIf ActiveStyle.Name = "18ga GA Jkt" Then
oSMDef.SheetMetalStyles.Item("18ga GA Jkt (Test)").Activate
ElseIf ActiveStyle.Name = "18ga SS 304L Solid" Then
oSMDef.SheetMetalStyles.Item("18ga SS 304L Solid (Test)").Activate
ElseIf ActiveStyle.Name = "20ga GA Brt" Then
oSMDef.SheetMetalStyles.Item("20ga GA Brt (Test)").Activate
ElseIf ActiveStyle.Name = "20ga GA Jkt" Then
oSMDef.SheetMetalStyles.Item("20ga GA Jkt (Test)").Activate
Else
oSMDef.SheetMetalStyles.Item("Default").Activate
Dim oSMDoc As PartDocument = oSMDef.Document
oSMDoc.PropertySets.Item("Design Tracking Properties").Item("Stock Number").Value = "Material no disponible para tolerancias"
oSMDoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value = "Material no disponible para tolerancias"
End If
Catch oEx As Exception
'MsgBox(oEx.Message & vbCrLf & oEx.StackTrace, vbExclamation, "")
Logger.Error(oEx.Message & vbCrLf & oEx.StackTrace)
End Try
Next
End Sub
Wesley Crihfield
(Not an Autodesk Employee)
