04-11-2022
05:58 PM
- Mute
- Permalink
- Report
04-11-2022
05:58 PM
You can look at the visible document collection.
The ilogic snippet will need to be changed to a property set version(API) otherwise the part number will be the document you called the rule from rather than the document in your visible documents loop. If you need help constructing just post back with the visible documents loop in place and also the required property set. Any questions ask away.
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
Regards
Alan
