mat_hijs
547 Views, 6 Replies
Issue with Automating Break Creation in iLogic
I have an issue with creating breaks in iLogic. More specifically I have an issue with creating multiple breaks. When I create one break it works perfectly, the break ends up in the correct position. But when I try to create a second break on the same view I can't get the position right.
What I'm trying to do is the following: I have a part that has some notches in it, one is always in the middle, and the others are always at the same spacing from the middle, both left and right. The amount of notches would depend on the length of the part. I want to show all the notches on my drawing, but I want to remove the spaces between them with breaks to make everything fit on my sheet. The first break I place is placed correctly, no matter if it is break 1 or break 2. The second one is not placed correctly as you can see in the attached images.
I attached a (dummy) part and a drawing that includes the rule I'm using. Could anyone tell me how the first break is impacting the second break and how I could account for that?
