04-06-2022
06:14 PM
- Mute
- Permalink
- Report
04-06-2022
06:14 PM
OK, Pending more testing I think I have found a solution.
Essentially I needed to rename all occurrences available from that BOM level to have a unique name (Sequentially numbered occurrence suffix)
Here is the currently working Code.
Sub Main
Dim oAdoc As AssemblyDocument
oAdoc = ThisApplication.ActiveDocument
'Check it is the active document that triggered this script
Dim activeDocName As String = oAdoc.FullFileName
Dim thisDocName As String = ThisDoc.Document.FullFileName
If (activeDocName <> thisDocName) Then
'the script was not triggered by the active document
Return
End If
'Check active document is an assembly
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
MessageBox.Show("This rule " & iLogicVb.RuleName & " only works for Assembly Documents.", "WRONG DOCUMENT TYPE", MessageBoxButtons.OK, MessageBoxIcon.Error)
Return
End If
'Get current Assembly TOTAL_QUANTITY value as Pack Quantity multiplier
Dim oPQ As String
oPQ = (iProperties.Value("Custom", "TOTAL_QUANTITY"))
Dim oCompDef As AssemblyComponentDefinition
oCompDef = oAdoc.ComponentDefinition
Dim asmOccurrences = oCompDef.Occurrences
'Get BOM Definition
Dim oBOM As BOM
oBOM = oCompDef.BOM
'Set BOM to structured view
oBOM.StructuredViewEnabled = True
oBOM.StructuredViewFirstLevelOnly = True
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item("Structured")
Dim oRow As BOMRow
'Lets rename all our occurrences to make them unique
OccCounter = 0
For Each oRow In oBOMView.BOMRows
'Message box for debugging
'MessageBox.Show(oRow.ItemNumber, "Debug-row")
For Each CompDef As ComponentDefinition In oRow.ComponentDefinitions
Dim occurrences = asmOccurrences.AllLeafOccurrences(CompDef)
For Each occ As ComponentOccurrence In occurrences
OccCounter = OccCounter + 1
'Removes the :x portion of name
NewName = (occ.Name.Split(":")(0))
'Trace.WriteLine(occ.Name & " - Original name - " & NewName)
'Append the new :x portion of name
NewName = NewName & ":" & OccCounter
If occ.Name = NewName Then
'Do nothing it's already that anyway
Else
Try
'Write new name
occ.Name = NewName
'MessageBox.Show(occ.Name, "Debug-Name")
Catch
Try
'Write new name with an A suffix. - Assumes fail was due to existing name in assembly already
occ.Name = NewName & "A"
'MessageBox.Show(occ.Name, "Debug-Name Retry")
Catch
MessageBox.Show(occ.Name & ": Count=" & OccCounter & ", Rename didn't work." & vbNewLine & "Please run again", "Debug - rename try")
Exit Sub
End Try
End Try
End If
Next
Next
Next
'Now lets write our instance Variable
Try
'MessageBox.Show(occ.Name & " - " & oPQ, "Debug-Name")
'Write the new instance Property
iProperties.InstanceValue(occ.Name, "PACK_QTY") = oPQ
Catch
MessageBox.Show(occ.Name & ", Instance property write failed" & vbNewLine & "Please run again", "Debug - Instance property - Write")
Exit Sub
End Try
Next
Next
Next
End Sub
