Thanks Dalton,
I think this is almost there.
It is however coming up with an error
"iProperties: The component named "Assembly1.iam" was not found."
That assembly certainly does exist in this test model.
I am thinking using the oDoc.Displayname may not be getting the correct definition name to apply the instance properties too?
The other thing is I am hoping I can run this in 'Firstlevelonly' so that it only applies to components in a 'phantom' sub assembly but not to components of a 'Normal' sub assembly.
