yan.gauthier
in reply to: paulZKN98
Ilogic uses VB.Net, what you are trying to do is called contatenation. It the process of combining several strings into one.
VB.Net uses "&" as its concatenation operator:
filename = iProperties.Value("Project", "Part Number") & " - " & iProperties.Value("Project", "Description")
Also, You cannot change a file name on the fly. It's only upon creating it that you can set its name. If it was possible, we would need a way to update every files that refers to this filename.
