04-06-2022
08:22 AM
- Mute
- Permalink
- Report
04-06-2022
08:22 AM
It's hard to say for sure without seeing the model, but it looks like you should be able to change your assembly to use Component Patterns, and then use a user parameter to change the number and/or the spacing of things (either using an iLogic form or a Rule). That should speed things up for you.
If you can't switch to patterns then you could look into writing functions to simplify your code and using user parameters to control the suppression states of different objects but I'm not sure if that would be faster or not.
