justinparfitt
169 Views, 1 Reply
Feature suppression based on handing and height
Hi Gents,
Could you please help me out with writing better code to handle hinge suppression based on handing and height.
My if else statement is very clunky, it works but it is not efficient, inventor freezes for 3-10min, depending, if you are changing door hand from single left hand to double right hand.
So, what I have is:
4 no. types of door hand : single left, single right, double left, double right
3 no. range of lengths to determine if 3 no. hinges is required or 4 or 5.
Below is my rule: If someone can point me in correct direction to utilise ilogic API, i would be very grateful.
If leg_top_edge < 2200 And (door_hand = "single right") Then
wp_2_hinge = (-leg_top_edge + 551) / 2 - 294
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:1") = True
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:2") = True
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:3") = True
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:4") = False
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:5") = False
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:1") = True
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:2") = True
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:3") = True
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:4") = False
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:5") = False
Component.IsActive("S.STEEL HINGE:1") = True
Component.IsActive("S.STEEL HINGE:2") = True
Component.IsActive("S.STEEL HINGE:3") = True
Component.IsActive("S.STEEL HINGE:4") = False
Component.IsActive("S.STEEL HINGE:5") = False
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:1") = False
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:2") = False
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:3") = False
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:4") = False
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:5") = False
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:6") = False
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:7") = False
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:8") = False
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:9") = False
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:10") = False
Component.IsActive("S.STEEL HINGE:6") = False
Component.IsActive("S.STEEL HINGE:7") = False
Component.IsActive("S.STEEL HINGE:8") = False
Component.IsActive("S.STEEL HINGE:9") = False
Component.IsActive("S.STEEL HINGE:10") = False
ElseIf leg_top_edge >= 2200 And leg_top_edge < 2400 And (door_hand = "single right") Then
wp_2_hinge = (-leg_top_edge + 801) / 2 - 544
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:4") = True
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:4") = True
Component.IsActive("S.STEEL HINGE:4") = True
ElseIf leg_top_edge >= 2400 And (door_hand = "single right") Then
wp_2_hinge = (-leg_top_edge + 1051) / 2 - 544
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:5") = True
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:5") = True
Component.IsActive("S.STEEL HINGE:5") = True
ElseIf leg_top_edge < 2200 And (door_hand = "single left") Then
wp_2_hinge = (-leg_top_edge+551)/2 -294
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:1") = False
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:2") = False
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:3") = False
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:1") = False
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:2") = False
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:3") = False
Component.IsActive("S.STEEL HINGE:1") = False
Component.IsActive("S.STEEL HINGE:2") = False
Component.IsActive("S.STEEL HINGE:3") = False
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:1") = True
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:2") = True
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:3") = True
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:6") = True
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:7") = True
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:8") = True
Component.IsActive("S.STEEL HINGE:6") = True
Component.IsActive("S.STEEL HINGE:7") = True
Component.IsActive("S.STEEL HINGE:8") = True
ElseIf leg_top_edge >= 2200 And leg_top_edge < 2400 And (door_hand = "single left") Then
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:4") = True
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:9") = True
Component.IsActive("S.STEEL HINGE:9") = True
ElseIf leg_top_edge >= 2400 And (door_hand = "single left") Then
wp_2_hinge = (-leg_top_edge+1051)/2 -544
Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:5") = True
Component.IsActive("FRAME HINGE PLATE ASSEMBLY:10") = True
Component.IsActive("S.STEEL HINGE:10") = True
ElseIf leg_top_edge < 2200 And (door_hand = "double left" Or door_hand = "double right") Then
wp_2_hinge = (-leg_top_edge+551)/2 - 294
ElseIf leg_top_edge >= 2200 And leg_top_edge < 2400 And (door_hand = "double left" Or door_hand = "double right") Then
ElseIf leg_top_edge >= 2400 And (door_hand = "double left" Or door_hand = "double right") Then
End If
'iLogicVb.UpdateWhenDone = True
InventorVb.DocumentUpdate()
