- Mute
- Permalink
- Report
Feature suppression based on handing and height
Hi Gents,
Could you please help me out with writing better code to handle hinge suppression based on handing and height.
My if else statement is very clunky, it works but it is not efficient, inventor freezes for 3-10min, depending, if you are changing door hand from single left hand to double right hand.
So, what I have is:
4 no. types of door hand : single left, single right, double left, double right
3 no. range of lengths to determine if 3 no. hinges is required or 4 or 5.
Below is my rule: If someone can point me in correct direction to utilise ilogic API, i would be very grateful.
If leg_top_edge < 2200 And (door_hand = "single right") Then wp_2_hinge = (-leg_top_edge + 551) / 2 - 294 Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:1") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:2") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:3") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:4") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:5") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:1") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:2") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:3") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:4") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:5") = False Component.IsActive("S.STEEL HINGE:1") = True Component.IsActive("S.STEEL HINGE:2") = True Component.IsActive("S.STEEL HINGE:3") = True Component.IsActive("S.STEEL HINGE:4") = False Component.IsActive("S.STEEL HINGE:5") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:1") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:2") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:3") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:4") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:5") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:6") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:7") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:8") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:9") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:10") = False Component.IsActive("S.STEEL HINGE:6") = False Component.IsActive("S.STEEL HINGE:7") = False Component.IsActive("S.STEEL HINGE:8") = False Component.IsActive("S.STEEL HINGE:9") = False Component.IsActive("S.STEEL HINGE:10") = False ElseIf leg_top_edge >= 2200 And leg_top_edge < 2400 And (door_hand = "single right") Then wp_2_hinge = (-leg_top_edge + 801) / 2 - 544 Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:1") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:2") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:3") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:4") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:5") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:1") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:2") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:3") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:4") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:5") = False Component.IsActive("S.STEEL HINGE:1") = True Component.IsActive("S.STEEL HINGE:2") = True Component.IsActive("S.STEEL HINGE:3") = True Component.IsActive("S.STEEL HINGE:4") = True Component.IsActive("S.STEEL HINGE:5") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:1") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:2") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:3") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:4") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:5") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:6") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:7") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:8") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:9") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:10") = False Component.IsActive("S.STEEL HINGE:6") = False Component.IsActive("S.STEEL HINGE:7") = False Component.IsActive("S.STEEL HINGE:8") = False Component.IsActive("S.STEEL HINGE:9") = False Component.IsActive("S.STEEL HINGE:10") = False ElseIf leg_top_edge >= 2400 And (door_hand = "single right") Then wp_2_hinge = (-leg_top_edge + 1051) / 2 - 544 Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:1") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:2") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:3") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:4") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:5") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:1") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:2") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:3") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:4") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:5") = True Component.IsActive("S.STEEL HINGE:1") = True Component.IsActive("S.STEEL HINGE:2") = True Component.IsActive("S.STEEL HINGE:3") = True Component.IsActive("S.STEEL HINGE:4") = True Component.IsActive("S.STEEL HINGE:5") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:1") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:2") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:3") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:4") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:5") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:6") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:7") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:8") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:9") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:10") = False Component.IsActive("S.STEEL HINGE:6") = False Component.IsActive("S.STEEL HINGE:7") = False Component.IsActive("S.STEEL HINGE:8") = False Component.IsActive("S.STEEL HINGE:9") = False Component.IsActive("S.STEEL HINGE:10") = False ElseIf leg_top_edge < 2200 And (door_hand = "single left") Then wp_2_hinge = (-leg_top_edge+551)/2 -294 Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:1") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:2") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:3") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:4") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:5") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:1") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:2") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:3") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:4") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:5") = False Component.IsActive("S.STEEL HINGE:1") = False Component.IsActive("S.STEEL HINGE:2") = False Component.IsActive("S.STEEL HINGE:3") = False Component.IsActive("S.STEEL HINGE:4") = False Component.IsActive("S.STEEL HINGE:5") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:1") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:2") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:3") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:4") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:5") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:6") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:7") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:8") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:9") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:10") = False Component.IsActive("S.STEEL HINGE:6") = True Component.IsActive("S.STEEL HINGE:7") = True Component.IsActive("S.STEEL HINGE:8") = True Component.IsActive("S.STEEL HINGE:9") = False Component.IsActive("S.STEEL HINGE:10") = False ElseIf leg_top_edge >= 2200 And leg_top_edge < 2400 And (door_hand = "single left") Then wp_2_hinge = (-leg_top_edge + 801) / 2 - 544 Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:1") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:2") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:3") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:4") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:5") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:1") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:2") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:3") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:4") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:5") = False Component.IsActive("S.STEEL HINGE:1") = False Component.IsActive("S.STEEL HINGE:2") = False Component.IsActive("S.STEEL HINGE:3") = False Component.IsActive("S.STEEL HINGE:4") = False Component.IsActive("S.STEEL HINGE:5") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:1") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:2") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:3") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:4") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:5") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:6") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:7") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:8") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:9") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:10") = False Component.IsActive("S.STEEL HINGE:6") = True Component.IsActive("S.STEEL HINGE:7") = True Component.IsActive("S.STEEL HINGE:8") = True Component.IsActive("S.STEEL HINGE:9") = True Component.IsActive("S.STEEL HINGE:10") = False ElseIf leg_top_edge >= 2400 And (door_hand = "single left") Then wp_2_hinge = (-leg_top_edge+1051)/2 -544 Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:1") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:2") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:3") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:4") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:5") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:1") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:2") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:3") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:4") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:5") = False Component.IsActive("S.STEEL HINGE:1") = False Component.IsActive("S.STEEL HINGE:2") = False Component.IsActive("S.STEEL HINGE:3") = False Component.IsActive("S.STEEL HINGE:4") = False Component.IsActive("S.STEEL HINGE:5") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:1") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:2") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:3") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:4") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:5") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:6") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:7") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:8") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:9") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:10") = True Component.IsActive("S.STEEL HINGE:6") = True Component.IsActive("S.STEEL HINGE:7") = True Component.IsActive("S.STEEL HINGE:8") = True Component.IsActive("S.STEEL HINGE:9") = True Component.IsActive("S.STEEL HINGE:10") = True ElseIf leg_top_edge < 2200 And (door_hand = "double left" Or door_hand = "double right") Then Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:1") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:2") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:3") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:4") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:5") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:1") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:2") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:3") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:4") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:5") = False Component.IsActive("S.STEEL HINGE:1") = True Component.IsActive("S.STEEL HINGE:2") = True Component.IsActive("S.STEEL HINGE:3") = True Component.IsActive("S.STEEL HINGE:4") = False Component.IsActive("S.STEEL HINGE:5") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:1") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:2") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:3") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:4") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:5") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:6") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:7") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:8") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:9") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:10") = False Component.IsActive("S.STEEL HINGE:6") = True Component.IsActive("S.STEEL HINGE:7") = True Component.IsActive("S.STEEL HINGE:8") = True Component.IsActive("S.STEEL HINGE:9") = False Component.IsActive("S.STEEL HINGE:10") = False wp_2_hinge = (-leg_top_edge+551)/2 - 294 ElseIf leg_top_edge >= 2200 And leg_top_edge < 2400 And (door_hand = "double left" Or door_hand = "double right") Then Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:1") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:2") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:3") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:4") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:5") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:1") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:2") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:3") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:4") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:5") = False Component.IsActive("S.STEEL HINGE:1") = True Component.IsActive("S.STEEL HINGE:2") = True Component.IsActive("S.STEEL HINGE:3") = True Component.IsActive("S.STEEL HINGE:4") = True Component.IsActive("S.STEEL HINGE:5") = False Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:1") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:2") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:3") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:4") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:5") = False Component.IsActive("FRAME HINGE PLATE ASSEMBLY:6") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:7") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:8") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:9") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:10") = False Component.IsActive("S.STEEL HINGE:6") = True Component.IsActive("S.STEEL HINGE:7") = True Component.IsActive("S.STEEL HINGE:8") = True Component.IsActive("S.STEEL HINGE:9") = True Component.IsActive("S.STEEL HINGE:10") = False wp_2_hinge = (-leg_top_edge + 801) / 2 - 544 ElseIf leg_top_edge >= 2400 And (door_hand = "double left" Or door_hand = "double right") Then Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:1") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:2") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:3") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:4") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_rh:5") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:1") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:2") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:3") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:4") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:5") = True Component.IsActive("S.STEEL HINGE:1") = True Component.IsActive("S.STEEL HINGE:2") = True Component.IsActive("S.STEEL HINGE:3") = True Component.IsActive("S.STEEL HINGE:4") = True Component.IsActive("S.STEEL HINGE:5") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:1") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:2") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:3") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:4") = True Feature.IsActive("FRAME MASTER PART:2", "frame_hinge_prep_lh:5") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:6") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:7") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:8") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:9") = True Component.IsActive("FRAME HINGE PLATE ASSEMBLY:10") = True Component.IsActive("S.STEEL HINGE:6") = True Component.IsActive("S.STEEL HINGE:7") = True Component.IsActive("S.STEEL HINGE:8") = True Component.IsActive("S.STEEL HINGE:9") = True Component.IsActive("S.STEEL HINGE:10") = True wp_2_hinge = (-leg_top_edge + 1051) / 2 - 544 End If 'iLogicVb.UpdateWhenDone = True InventorVb.DocumentUpdate()
- Mute
- Permalink
- Report
It's hard to say for sure without seeing the model, but it looks like you should be able to change your assembly to use Component Patterns, and then use a user parameter to change the number and/or the spacing of things (either using an iLogic form or a Rule). That should speed things up for you.
If you can't switch to patterns then you could look into writing functions to simplify your code and using user parameters to control the suppression states of different objects but I'm not sure if that would be faster or not.
