Here is some VBA code to get you started.  Just replace the text "AddInDisplayName" with the name DisplayName of the AddIn you want to work with.  Or, if you know the Class ID of the AddIn, you can skip or delete the loop, and just use the other means (commented out) of identifying the AddIn you want to work with.
Sub ToggleAddIn()
    Dim oAddIns As ApplicationAddIns
    Set oAddIns = ThisApplication.ApplicationAddIns
    Dim oAddIn As ApplicationAddIn
    For Each oAddIn In oAddIns
        If oAddIn.DisplayName = "AddInDisplayName" Then
            If oAddIn.Activated Then
                oAddIn.Deactivate
            Else
                oAddIn.Activate
            End If
        End If
    Next
    'Dim oMyAddIn As ApplicationAddIn
    'Set oMyAddIn = oAddIns.ItemById("{.......}")
    'oMyAddIn.Activate
End Sub
Wesley Crihfield
(Not an Autodesk Employee)
