abhay.gilka
451 Views, 3 Replies
Is there Tool Palette equivakent for Inventor
Im looking to organise all ifeature parts in a similar way we do for Autocad blocks using Tool Palette.
Is there an option in Inventor to quickly click and place ifeatures?
Could you please try to explain me a bit more in detail what your are expecting?
Arthur Knoors
Autodesk Affiliations:
I am interested to know if we can create quick acess tool bar with ifeatures from specific folder location.
This is a built-in function. See tab Manage-Insert in part environment. There is a comboBox with all iFeatures from "Catalog" which is defined in application options
