WCrihfield
in reply to: emanuel.c
We can stick with the AllReferencedDocuments route, if we populate the Description iProperty from the Document's file name.  Here is a fairly simple example iLogic code that will do that task.  I separated the main process out into its own Sub routine, and I am also using a Try...Catch block within that to help handle/avoid the potential errors.  It is sometimes possible that not every referenced document is a regular Inventor Part or Assembly document.
Sub Main
	oDoc = ThisDoc.Document
	WriteFileNameToDescription(oDoc)
	If oDoc.AllReferencedDocuments.Count = 0 Then Exit Sub
	For Each oRefDoc As Document In oDoc.AllReferencedDocuments
		WriteFileNameToDescription(oRefDoc)
	Next
End Sub
Sub WriteFileNameToDescription(oDoc As Document)
	Try
		'gets file name, without path, and without file extension
		oFileName = System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName)
		oDescProp = oDoc.PropertySets.Item("Design Tracking Properties").Item("Description")
		If oDescProp.Value <> oFileName Then oDescProp.Value = oFileName
	Catch oEx As Exception
		MsgBox(oEx.Message & vbCrLf & oEx.StackTrace, vbExclamation, "")
		'Logger.Error(oEx.Message & vbCrLf & oEx.StackTrace)
	End Try
End Sub
Wesley Crihfield
(Not an Autodesk Employee)
