WCrihfield
in reply to: emanuel.c
Writing assembly level data back down into sub-assembly & part level documents is often a bad idea.  There are several situations where the data may be written over multiple times, which can result in incorrect & misleading information without it being obvious that there is a problem.  Especially in situations where the same document may be represented by components in multiple other main assemblies, or the same document may be represented by components in multiple levels of the same main assembly structure.  What do you plan on doing with this 'component name' information in the description iProperty, once the task of writing the data out is done?  If there are multiple components that represent the same document, which component name should be written to the document?
Wesley Crihfield
(Not an Autodesk Employee)
