Ralf_Krieg
in reply to: pmartick
Hello
The MiniToolbarComboBox.AddItem method needs an IPictureDisp for small (16x16px) and large (32x32px) Icon. If you display only small icons and the user had no possibility to switch to large icons, you do not need to add them.
Most parts of the conversion is "stolen" from the Autodesk Inventor Addin template for Visual Studio. There is for sure a cleaner, better and right way to do this, but I'm not experienced enough for it.
I have hard coded the path to the icon files. You'll need to change the path and add some checks if path exist, if there is an icon file and so on.
AddReference "System.Drawing"
AddReference "stdole"
AddReference "System.Windows.Forms"
Class ThisRule
	Dim bStop As Boolean = False
	Dim cOccs As Inventor.ComponentOccurrences
	Dim oImageLarge As System.Drawing.Image
	Dim oImageSmall As System.Drawing.Image
	Dim oIconLarge As System.Drawing.Icon
	Dim oIconSmall As System.Drawing.Icon
	Dim oIPicDispLarge As stdole.IPictureDisp
	Dim oIPicDispSmall As stdole.IPictureDisp
	Private WithEvents evMiniToolbar As Inventor.MiniToolbar
	Private WithEvents evInteractionEvents As Inventor.InteractionEvents
	Private WithEvents evSelectEvents As Inventor.SelectEvents
	Private WithEvents evKeyboardEvents As Inventor.KeyboardEvents
	Private WithEvents evComboBox As Inventor.MiniToolbarComboBox
	Sub Main
		oApp = ThisApplication
		oDoc = ThisDoc.Document
		oIconLarge = New System.Drawing.Icon("C:\Temp\ico_Large_32x32.ico")
		oIconSmall = New System.Drawing.Icon("C:\Temp\ico_Small_16x16.ico")
		oImageLarge = oIconLarge.ToBitmap
		oImageSmall = oIconSmall.ToBitmap
		Dim myPict As New AxHostConverter
		oIPicDispLarge = myPict.GetIPictureDispFromImage(oImageLarge)
		oIPicDispSmall = myPict.GetIPictureDispFromImage(oImageSmall)
		'this call must be created, but is never used
		Dim myCallback As New System.Drawing.Image.GetThumbnailImageAbort(AddressOf ThumbnailCallback)
		If TypeOf oDoc Is AssemblyDocument And Right(oApp.UserInterfaceManager.ActiveEnvironment.DisplayName,  = "Assembly" Then
			cOccs = oDoc.ComponentDefinition.Occurrences
			oCommandManager = oApp.CommandManager
			evMiniToolbar = oCommandManager.CreateMiniToolbar
			evInteractionEvents = oCommandManager.CreateInteractionEvents
			evSelectEvents = evInteractionEvents.SelectEvents
			evSelectEvents.AddSelectionFilter(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter)
			evSelectEvents.WindowSelectEnabled = False
			evSelectEvents.Enabled = True
			evMiniToolbarControls = evMiniToolbar.Controls
			oView = oApp.ActiveView
			evMiniToolbar.Position = oApp.TransientGeometry.CreatePoint2d(oView.Left, oView.Top)
			evMiniToolbar.ShowOK = True
			evMiniToolbar.ShowOptionBox = False
			evMiniToolbarControls.AddLabel("MainLabel", "Select occurrences.", "Occurrences")
			evMiniToolbarControls.AddNewLine
			evMiniToolbarControls.AddLabel("Selection:", "Selection", "Select Occurrences.")
			evComboBox = evMiniToolbarControls.AddComboBox("Selection")
			evComboBox.AutoHide = False
			evMiniToolbar.Visible = True
			evInteractionEvents.Start
			Do
				oApp.UserInterfaceManager.DoEvents
			Loop Until bStop = True
			evInteractionEvents.Stop
			evMiniToolbar.Delete
		Else
			MessageBox.Show("This rule must be run in an Assembly Environment.")
		End If
	End Sub
	Sub evMiniToolbar_OnApply() Handles evMiniToolbar.OnApply
		evSelectEvents.ResetSelections
	End Sub
	Sub evMiniToolbar_OnOK() Handles evMiniToolbar.OnOK
		bStop = True
	End Sub
	Sub evMiniToolbar_OnCancel() Handles evMiniToolbar.OnCancel
		bStop = True
	End Sub
	Sub evKeyboardEvents_OnKeyPress(lKey As Long) Handles evKeyboardEvents.OnKeyPress
		If lKey = 27 Then evMiniToolbar_OnCancel
		If lKey = 10 Then evMiniToolbar_OnApply
	End Sub
	Sub evSelectEvents_OnPreSelect(ByRef PreSelectEntity As Object, ByRef DoHighlight As Boolean, ByRef MorePreSelectEntities As Inventor.ObjectCollection, ByVal SelectionDevice As Inventor.SelectionDeviceEnum, ByVal ModelPosition As Inventor.Point, ByVal ViewPosition As Inventor.Point2d, ByVal View As Inventor.View) Handles evSelectEvents.OnPreSelect
		PreSelectEntity = PreSelectEntity.OccurrencePath.Item(1)
	End Sub
	Sub evSelectEvents_OnSelect(ByVal JustSelectedEntities As Inventor.ObjectsEnumerator, ByVal SelectionDevice As Inventor.SelectionDeviceEnum, ByVal ModelPosition As Inventor.Point, ByVal ViewPosition As Inventor.Point2d, ByVal View As Inventor.View) Handles evSelectEvents.OnSelect
		oEntity = JustSelectedEntities.Item(1)
		sEntity = oEntity.Name
		evSelectEvents.AddToSelectedEntities(oEntity)
		'oIcon = ThisDoc.Document.BrowserPanes.GetNativeBrowserNodeDefinition(oEntity).Icon
		evComboBox.AddItem(sEntity, "Occurrence", sEntity, True, oIPicDispSmall,oIPicDispLarge)
	End Sub
	Sub evSelectEvents_OnUnSelect(ByVal UnSelectedEntities As Inventor.ObjectsEnumerator, ByVal SelectionDevice As Inventor.SelectionDeviceEnum, ByVal ModelPosition As Inventor.Point, ByVal ViewPosition As Inventor.Point2d, ByVal View As Inventor.View) Handles evSelectEvents.OnUnSelect
		evComboBox.RemoveItem(UnSelectedEntities.Item(1).Name)
	End Sub
	Sub evComboBox_OnItemRemove(ByVal oItem As Inventor.MiniToolbarListItem) Handles evComboBox.OnItemRemove
		evSelectEvents.RemoveFromSelectedEntities(cOccs.ItemByName(oItem.InternalName))
	End Sub
	Public Function ThumbnailCallback() As Boolean
		Return False
	End Function
End Class
Class AxHostConverter
Inherits System.Windows.Forms.AxHost
Public Sub New()
	MyBase.New("{63109182-966B-4e3c-A8B2-8BC4A88D221C}")
End Sub
Public Function GetImageFromIPictureDisp(ByVal pictureDisp As stdole.IPictureDisp) As System.Drawing.Image
	Return MyBase.GetPictureFromIPicture(pictureDisp)
End Function
Public Function GetIPictureDispFromImage(ByVal image As System.Drawing.Image) As stdole.IPictureDisp
	Return MyBase.GetIPictureDispFromPicture(image)
End Function
End Class
R. Krieg
RKW Solutions
www.rkw-solutions.com
