- Mute
- Permalink
- Report
Inventor 2021, latest version:
I have a sample of a rule I'm making that uses a Mini Toolbar to allow the user to select component occurrences in an assembly and see them in a combo box. I see in the API Guide that there's an option to have an icon next to each combo box item. I'm trying to find the way to grab the icon from the browser node of the selected occurrence (icons for Part, Assembly, Weldment, Sheet Metal, etc.) and use that as the icon in the combo box.
When adding the combo box item, it accepts IPictureDisp as an icon input. I think I found the API to grab the icon from the selected occurrence which results as an IPictureDisp:
ThisDoc.Document.BrowserPanes.GetNativeBrowserNodeDefinition(oEntity).Icon
However, when I try to use this to contain the icon in an object I get an error:
Error : Reference required to assembly 'stdole, Version=7.0.3300.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' containing the type 'stdole.IPictureDisp'. Add one to your project.
I'm not sure how to properly set up "stdole.IPictureDisp" as a reference in iLogic or if it's even possible.
Here's my rule sample, the area where the icon needs to be grabbed and used is in subroutine evSelectEvents_OnSelect:
Class ThisRule Dim bStop As Boolean = False Dim cOccs As Inventor.ComponentOccurrences Private WithEvents evMiniToolbar As Inventor.MiniToolbar Private WithEvents evInteractionEvents As Inventor.InteractionEvents Private WithEvents evSelectEvents As Inventor.SelectEvents Private WithEvents evKeyboardEvents As Inventor.KeyboardEvents Private WithEvents evComboBox As Inventor.MiniToolbarComboBox Sub Main oApp = ThisApplication oDoc = ThisDoc.Document If TypeOf oDoc Is AssemblyDocument And Right(oApp.UserInterfaceManager.ActiveEnvironment.DisplayName, 8) = "Assembly" Then cOccs = oDoc.ComponentDefinition.Occurrences oCommandManager = oApp.CommandManager evMiniToolbar = oCommandManager.CreateMiniToolbar evInteractionEvents = oCommandManager.CreateInteractionEvents evSelectEvents = evInteractionEvents.SelectEvents evSelectEvents.AddSelectionFilter(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter) evSelectEvents.WindowSelectEnabled = False evSelectEvents.Enabled = True evMiniToolbarControls = evMiniToolbar.Controls oView = oApp.ActiveView evMiniToolbar.Position = oApp.TransientGeometry.CreatePoint2d(oView.Left, oView.Top) evMiniToolbar.ShowOK = True evMiniToolbar.ShowOptionBox = False evMiniToolbarControls.AddLabel("MainLabel", "Select occurrences.", "Occurrences") evMiniToolbarControls.AddNewLine evMiniToolbarControls.AddLabel("Selection:", "Selection", "Select Occurrences.") evComboBox = evMiniToolbarControls.AddComboBox("Selection") evComboBox.AutoHide = False evMiniToolbar.Visible = True evInteractionEvents.Start Do oApp.UserInterfaceManager.DoEvents Loop Until bStop = True evInteractionEvents.Stop evMiniToolbar.Delete Else MessageBox.Show("This rule must be run in an Assembly Environment.") End If End Sub Sub evMiniToolbar_OnApply() Handles evMiniToolbar.OnApply evSelectEvents.ResetSelections End Sub Sub evMiniToolbar_OnOK() Handles evMiniToolbar.OnOK bStop = True End Sub Sub evMiniToolbar_OnCancel() Handles evMiniToolbar.OnCancel bStop = True End Sub Sub evKeyboardEvents_OnKeyPress(lKey As Long) Handles evKeyboardEvents.OnKeyPress If lKey = 27 Then evMiniToolbar_OnCancel If lKey = 10 Then evMiniToolbar_OnApply End Sub Sub evSelectEvents_OnPreSelect(ByRef PreSelectEntity As Object, ByRef DoHighlight As Boolean, ByRef MorePreSelectEntities As Inventor.ObjectCollection, ByVal SelectionDevice As Inventor.SelectionDeviceEnum, ByVal ModelPosition As Inventor.Point, ByVal ViewPosition As Inventor.Point2d, ByVal View As Inventor.View) Handles evSelectEvents.OnPreSelect PreSelectEntity = PreSelectEntity.OccurrencePath.Item(1) End Sub Sub evSelectEvents_OnSelect(ByVal JustSelectedEntities As Inventor.ObjectsEnumerator, ByVal SelectionDevice As Inventor.SelectionDeviceEnum, ByVal ModelPosition As Inventor.Point, ByVal ViewPosition As Inventor.Point2d, ByVal View As Inventor.View) Handles evSelectEvents.OnSelect oEntity = JustSelectedEntities.Item(1) sEntity = oEntity.Name evSelectEvents.AddToSelectedEntities(oEntity) oIcon = ThisDoc.Document.BrowserPanes.GetNativeBrowserNodeDefinition(oEntity).Icon evComboBox.AddItem(sEntity, "Occurrence", sEntity, True, oIcon) End Sub Sub evSelectEvents_OnUnSelect(ByVal UnSelectedEntities As Inventor.ObjectsEnumerator, ByVal SelectionDevice As Inventor.SelectionDeviceEnum, ByVal ModelPosition As Inventor.Point, ByVal ViewPosition As Inventor.Point2d, ByVal View As Inventor.View) Handles evSelectEvents.OnUnSelect evComboBox.RemoveItem(UnSelectedEntities.Item(1).Name) End Sub Sub evComboBox_OnItemRemove(ByVal oItem As Inventor.MiniToolbarListItem) Handles evComboBox.OnItemRemove evSelectEvents.RemoveFromSelectedEntities(cOccs.ItemByName(oItem.InternalName)) End Sub End Class
If this is something that's not possible in iLogic by either adding something in the Class or opening the Header and adding Imports or something else along those lines, then let me know and I'll add this to the Ideas forum.
Thank you for your help.
- Mute
- Permalink
- Report
Hello
Add in the header section of your rule just
AddReference "stdole"
R. Krieg
RKW Solutions
www.rkw-solutions.com
- Mute
- Permalink
- Report
Just put this into the 'Header' of the rule:
AddReference "stdole.dll"
Imports stdole
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS)
If you want and have time, I would appreciate your Vote(s) for My IDEAS :bulb: or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
- Mute
- Permalink
- Report
Hopefully another easily answered question that's related. How do I use other icons either found in Inventor or saved externally in the proper image format?
- Mute
- Permalink
- Report
Hi @pmartick. I believe that most (if not all) of the internal images within Inventor that we have access to from the Inventor API are in that same IPictureDisp format. The document thumbnail is that format, and the ribbon tool buttons also use that same format for their large and small icons. I used to use a VBA macro to extract the button icons from existing Inventor tool buttons, so that I could slightly alter them then reuse them as button icons for my own custom buttons, which ran some of my VBA macros. I just used to save them out as .bmp files though. It was much easier to do from VBA at the time than it was from iLogic. However, I'm steering away from VBA as much as possible now though, due to the related security issues, which is why Inventor no longer installs the VBA Editor with Inventor. You can also just create your own icon images from scratch though, if you are aware of the size restrictions, naming conventions, and file location requirements. There are several other articles here in the forums, in users blogs, and else where about folks using various other software to generate tool button icon graphics. (Link1, Link2)
Wesley Crihfield
- Mute
- Permalink
- Report
Hello
The MiniToolbarComboBox.AddItem method needs an IPictureDisp for small (16x16px) and large (32x32px) Icon. If you display only small icons and the user had no possibility to switch to large icons, you do not need to add them.
Most parts of the conversion is "stolen" from the Autodesk Inventor Addin template for Visual Studio. There is for sure a cleaner, better and right way to do this, but I'm not experienced enough for it.
I have hard coded the path to the icon files. You'll need to change the path and add some checks if path exist, if there is an icon file and so on.
AddReference "System.Drawing"
AddReference "System.Windows.Forms"
Class ThisRule
Dim oImageLarge As System.Drawing.Image
Dim oImageSmall As System.Drawing.Image
Dim oIconLarge As System.Drawing.Icon
Dim oIconSmall As System.Drawing.Icon
Dim oIPicDispLarge As stdole.IPictureDisp
Dim oIPicDispSmall As stdole.IPictureDisp
Sub Main
oIconLarge = New System.Drawing.Icon("C:\Temp\ico_Large_32x32.ico")
oIconSmall = New System.Drawing.Icon("C:\Temp\ico_Small_16x16.ico")
oImageLarge = oIconLarge.ToBitmap
oImageSmall = oIconSmall.ToBitmap
Dim myPict As New AxHostConverter
oIPicDispLarge = myPict.GetIPictureDispFromImage(oImageLarge)
oIPicDispSmall = myPict.GetIPictureDispFromImage(oImageSmall)
'this call must be created, but is never used
Dim myCallback As New System.Drawing.Image.GetThumbnailImageAbort(AddressOf ThumbnailCallback)
If TypeOf oDoc Is AssemblyDocument And Right(oApp.UserInterfaceManager.ActiveEnvironment.DisplayName, = "Assembly" Then
Do
Else
End If
End Sub
End Sub
bStop = True
End Sub
bStop = True
End Sub
End Sub
End Sub
'oIcon = ThisDoc.Document.BrowserPanes.GetNativeBrowserNodeDefinition(oEntity).Icon
evComboBox.AddItem(sEntity, "Occurrence", sEntity, True, oIPicDispSmall,oIPicDispLarge)
End Sub
End Sub
End Sub
Public Function ThumbnailCallback() As Boolean
Return False
End Function
End Class
Class AxHostConverter
Inherits System.Windows.Forms.AxHost
Public Sub New()
MyBase.New("{63109182-966B-4e3c-A8B2-8BC4A88D221C}")
End Sub
Public Function GetImageFromIPictureDisp(ByVal pictureDisp As stdole.IPictureDisp) As System.Drawing.Image
Return MyBase.GetPictureFromIPicture(pictureDisp)
End Function
Public Function GetIPictureDispFromImage(ByVal image As System.Drawing.Image) As stdole.IPictureDisp
Return MyBase.GetIPictureDispFromPicture(image)
End Function
End Class
R. Krieg
RKW Solutions
- Mute
- Permalink
- Report
However, for this line:
I don't get any errors when I comment out that line, is it just a sort of fault correction in case the .ico files can't be accessed?
- Mute
- Permalink
- Report
