Hi @nowell.colsenXK53F.  Just in case you were looking for more of a file dialog, so that you can select a file, instead of the Pick function, some code like this might be useful to you.  It is a simple custom Function with no 'input' variables, that will open a file dialog (just like when you use Inventor's Open dialog), but it doesn't actually open the selected file.  Instead it just returns the full file name of the selected file.
Sub Main
	oFileName = SelectFile
	MsgBox("oFileName = " & oFileName,,"")
End Sub
Function SelectFile() As String
	Dim oFileDialog As Inventor.FileDialog
	ThisApplication.CreateFileDialog(oFileDialog)
	oFileDialog.DialogTitle = "Select A File."
	oFileDialog.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath
	oFileDialog.Filter = "Autodesk Inventor Files (*.iam;*.dwg;*.idw;*.ipt:*.ipn;*.ide) | *.iam;*.dwg;*.idw;*ipt;*.ipn;*.ide | All files (*.*)|*.*"
	oFileDialog.MultiSelectEnabled = False
	oFileDialog.OptionsEnabled = False
	oFileDialog.InsertMode = False
	oFileDialog.CancelError = True
	Try
		oFileDialog.ShowOpen
		Return oFileDialog.FileName
	Catch
		Return ""
	End Try
End Function
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) :thumbs_up:.
If you want and have time, I would appreciate your Vote(s) for My IDEAS :bulb: or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
