03-22-2022
12:55 AM
- Mute
- Permalink
- Report
03-22-2022
12:55 AM
You can handle OnDoubleClick event from UserInputEvents. This is a small example how to do it in iLogic. Main code is in class SketchedSymbolDoubleClickHandler. Usage of SharedVariable is necessary to keep the handler alive between rule edits.
Sub Main()
Dim doubleClickHandler As SketchedSymbolDoubleClickHandler
Dim name = "DoubleClickHandler"
If SharedVariable.Exists(name) Then
doubleClickHandler = SharedVariable.Value(name)
Else
doubleClickHandler = New SketchedSymbolDoubleClickHandler(ThisApplication)
SharedVariable.Value(name) = doubleClickHandler
End If
If doubleClickHandler.IsActive Then
doubleClickHandler.StopHandling()
Else
doubleClickHandler.StartHandling()
End If
End Sub
Class SketchedSymbolDoubleClickHandler
Implements IDisposable
Private ReadOnly inventor As Application
Private userInputEvents As UserInputEvents
Public Sub New(inventor As Inventor.Application)
Me.inventor = inventor
End Sub
Public Sub StartHandling()
userInputEvents = inventor.CommandManager.UserInputEvents
AddHandler userInputEvents.OnDoubleClick, AddressOf UserInputEvents_OnDoubleClick
IsActive = True
End Sub
Public Sub StopHandling()
If userInputEvents Is Nothing Then Return
RemoveHandler userInputEvents.OnDoubleClick, AddressOf UserInputEvents_OnDoubleClick
userInputEvents = Nothing
IsActive = False
End Sub
Public Property IsActive As Boolean
Private Sub UserInputEvents_OnDoubleClick(selectedentities As ObjectsEnumerator,
selectiondevice As SelectionDeviceEnum,
button As MouseButtonEnum,
shiftkeys As ShiftStateEnum,
modelposition As Point,
viewposition As Point2d,
view As View,
additionalinfo As NameValueMap,
ByRef handlingcode As HandlingCodeEnum)
Dim sketchedSymbol As SketchedSymbol = Nothing
For Each entity As Object In selectedentities
If TypeOf entity Is SketchedSymbol Then
sketchedSymbol = entity
Exit For
End If
Next
If sketchedSymbol Is Nothing Then
handlingcode = HandlingCodeEnum.kEventNotHandled
Exit Sub
End If
'Implement your logic here
Dim msgList As New List(Of String)
msgList.Add("Name: " & sketchedSymbol.Name)
msgList.Add("Button: " & [Enum].GetName(GetType(MouseButtonEnum), button))
msgList.Add("ShiftKeys: " & [Enum].GetName(GetType(ShiftStateEnum), shiftkeys))
msgList.Add(String.Format("Model position: [{0:N3}, {1:N3}, {2:N3}]", modelposition.X, modelposition.Y, modelposition.Z))
msgList.Add(String.Format("View position: [{0}, {1}]", viewposition.X, viewposition.Y))
Dim msg = String.Join(vbCrLf, msgList)
MsgBox(msg, Title:="OnDoubleClick")
handlingcode = HandlingCodeEnum.kEventHandled
End Sub
Public Sub Dispose() Implements IDisposable.Dispose
StopHandling()
End Sub
End Class
