- Mute
- Permalink
- Report
I programmatically place some sketched symbols in a drawing. When the user double-clicks on such a symbol I want to open a custom dialog and not the standard Inventor dialog.
How can this be done?
Stephan
- Mute
- Permalink
- Report
You can handle OnDoubleClick event from UserInputEvents. This is a small example how to do it in iLogic. Main code is in class SketchedSymbolDoubleClickHandler. Usage of SharedVariable is necessary to keep the handler alive between rule edits.
Sub Main()
Dim doubleClickHandler As SketchedSymbolDoubleClickHandler
Dim name = "DoubleClickHandler"
If SharedVariable.Exists(name) Then
doubleClickHandler = SharedVariable.Value(name)
Else
doubleClickHandler = New SketchedSymbolDoubleClickHandler(ThisApplication)
SharedVariable.Value(name) = doubleClickHandler
End If
If doubleClickHandler.IsActive Then
doubleClickHandler.StopHandling()
Else
doubleClickHandler.StartHandling()
End If
End Sub
Class SketchedSymbolDoubleClickHandler
Implements IDisposable
Private ReadOnly inventor As Application
Private userInputEvents As UserInputEvents
Public Sub New(inventor As Inventor.Application)
Me.inventor = inventor
End Sub
Public Sub StartHandling()
userInputEvents = inventor.CommandManager.UserInputEvents
AddHandler userInputEvents.OnDoubleClick, AddressOf UserInputEvents_OnDoubleClick
IsActive = True
End Sub
Public Sub StopHandling()
If userInputEvents Is Nothing Then Return
RemoveHandler userInputEvents.OnDoubleClick, AddressOf UserInputEvents_OnDoubleClick
userInputEvents = Nothing
IsActive = False
End Sub
Public Property IsActive As Boolean
Private Sub UserInputEvents_OnDoubleClick(selectedentities As ObjectsEnumerator,
selectiondevice As SelectionDeviceEnum,
button As MouseButtonEnum,
shiftkeys As ShiftStateEnum,
modelposition As Point,
viewposition As Point2d,
view As View,
additionalinfo As NameValueMap,
ByRef handlingcode As HandlingCodeEnum)
Dim sketchedSymbol As SketchedSymbol = Nothing
For Each entity As Object In selectedentities
If TypeOf entity Is SketchedSymbol Then
sketchedSymbol = entity
Exit For
End If
Next
If sketchedSymbol Is Nothing Then
handlingcode = HandlingCodeEnum.kEventNotHandled
Exit Sub
End If
'Implement your logic here
Dim msgList As New List(Of String)
msgList.Add("Name: " & sketchedSymbol.Name)
msgList.Add("Button: " & [Enum].GetName(GetType(MouseButtonEnum), button))
msgList.Add("ShiftKeys: " & [Enum].GetName(GetType(ShiftStateEnum), shiftkeys))
msgList.Add(String.Format("Model position: [{0:N3}, {1:N3}, {2:N3}]", modelposition.X, modelposition.Y, modelposition.Z))
msgList.Add(String.Format("View position: [{0}, {1}]", viewposition.X, viewposition.Y))
Dim msg = String.Join(vbCrLf, msgList)
MsgBox(msg, Title:="OnDoubleClick")
handlingcode = HandlingCodeEnum.kEventHandled
End Sub
Public Sub Dispose() Implements IDisposable.Dispose
StopHandling()
End Sub
End Class
- Mute
- Permalink
- Report
Hello
How do you "start" the handler? OnOpenDocument event? What if a second drawing is opened? As I see the handler is stopped at this moment. Please, can you explain in short why you implement IDisposable?
Would love to see a solution handling such events in iLogic in a proper way. Until now I always switch to an Addin at this point.
R. Krieg
RKW Solutions
www.rkw-solutions.com
- Mute
- Permalink
- Report
For production is much better to use it in addin, but for this forum I need some way, how to test the code without any addin implementation.
This example is iLogic script and you can start them in standard way by "Run Rule".
After that the shared variable "DoubleClickHandler" is ensured and its value is instance of class "SketchedSymbolDoubleClickHandler". This is because I need to keep the handler alive between rule edits. (Not necessary when you use it in addin.)
After that I switch the state of handler Active/Inactive.
I implement interface IDisposable for cleanup reason, because I need to remove the event handler. For cleanup I use my own external rule instead of standard SharedVariable.RemoveAll() method. In standard way the list of shared variables is cleared, but if you have an event handler active, the object can not be removed from memory and the event handler is still active.
This is my rule to cleanup SharedVariables object. It is little bit hackish, but it works for debugging purposes.
Dim bindingFlags As Reflection.BindingFlags = System.Reflection.BindingFlags.NonPublic + System.Reflection.BindingFlags.GetField + System.Reflection.BindingFlags.Instance
Dim variables = SharedVariable.GetType().InvokeMember("m_ruleTempStorage", bindingFlags, Nothing, SharedVariable, Nothing)
Logger.Debug(variables.Count)
For Each keyValue In variables
Dim v = keyValue.Value
Logger.Debug(v.GetType().Name)
If TypeOf v Is IDisposable Then
v.Dispose
Logger.Debug(" - Disposed")
End If
Next
SharedVariable.RemoveAll()The similar solution I use for AddIns also, because I can keep many handlers in one collection and I can clean up them in single For Each loop.
- Mute
- Permalink
- Report
