891 Views, 5 Replies
iLogic
So I've created an ipt file that uses iLogic to automate the design of the part I want to make. With each part, I also need to generate a drawing, so I was wondering if there is some sort of coding in iLogic that I can put in a rule to run whenever I want to generate a drawing from the part I have. The placement of the dimensions and types of views are always the same, so if the drawing could automate those as well that would be awesome.
I've researched this already, but all the solutions I've found utilize imports, and I don't know how to access those libraries. So, if there's a way around that I'd like to know, and if not then how do you utilize imports?
