- Mute
- Permalink
- Report
Hi Krieg.
I see that the images are about 8 Mb.
Is that correct?
That's not exactly my intention, the jpg's I make using oDoc.SaveAs(NewImageFileName, True) are no larger than about 400 Kb, which is very handy.
May I ask you the question differently.
How can I get those images, which are already there anyway, in an Excel cell.
I've done some research and tried that, but to no avail.
I manage to get them into the Excel file, but not to the location so that they come in a cell or have the location of a cell.
So they all come together.
I also more or less understood that the images are over it which is fine by the way.
This is what I've tried, thereafter more code to see my complete struggle.
This one looks great but I do not know how to get it working:
With ExcelApp.oExcelSheet.Pictures.Insert(fileName)
' With .ShapeRange
' .LockAspectRatio = msoTrue
' .Width = 75
' .Height = 100
' End With
' .Left = ExcelApp.oExcelSheet.Cells(j, 20).Left
' .Top = ExcelApp.oExcelSheet.Cells(j, 20).Top
' .Placement = 1
' .PrintObject = True
' End With
' Set an Excel file for the Parts
' Fill an Excel file
' Get the Inventor user name From the Inventor Options
myName= ThisApplication.GeneralOptions.UserName
' Define the file to create/open
Dim TEST_BoM_All_Parts As String = sProject_PO_Folder & "TEST_BoM_All_Parts.xlsx"
myXLS_File = TEST_BoM_All_Parts
'MsgBox(TEST_BoM_All_Parts)
'Get the Inventor user name From the Inventor Options
' Define Excel Application object
'ExcelApp = CreateObject("Excel.Application")
Dim ExcelApp As New Excel.Application 'Create a new Excel Application
' Set Excel to run visibly, change to false if you want to run it invisibly
'ExcelApp.Visible = True
ExcelApp.Visible = False
' Suppress prompts (such as the compatibility checker)
ExcelApp.DisplayAlerts = False
' Check for existing file
' Delete file, to avoid error regarding Table
If System.IO.File.Exists(myXLS_File) Then System.IO.File.Delete(myXLS_File)
Dim oWB
If Dir(myXLS_File) <> "" Then
' Workbook exists, open it
oWB = ExcelApp.Workbooks.Open(myXLS_File)
'oExcelSheet = oWB.Worksheets(1)
Else
' Create a new spreadsheet from template
oWB = ExcelApp.Workbooks.Add '(Template: = "C:\Temp\HML_BoM_PO.xlt")
End If
' Insert data into Excel.
'With ExcelApp
' .Range("A1").Select
' .ActiveCell.FormulaR1C1 = "Hello, " & myName
'End With
Dim oExcelSheet
oExcelSheet = oWB.Worksheets.Item(1)
Dim oCells
oCells = oExcelSheet.Cells
' Create column headers
' First number is Row index, second number is Column Index
oCells.Item(1, 1).Value = "Thumbnail"
oCells.Item(1, 2).Value = "QTY"
oCells.Item(1, 3).Value = "Material+Thick+Fabr"
oCells.Item(1, 4).Value = "Part Number"
oCells.Item(1, 5).Value = "REV"
oCells.Item(1, 6).Value = "Description"
oCells.Item(1, 7).Value = "Finishing"
oCells.Item(1, 8).Value = "Dimensions" '"Parameters"
oCells.Item(1, 9).Value = "Bends"
oCells.Item(1, 10).Value = "Tapping"
oCells.Item(1, 11).Value = "CSINK"
oCells.Item(1, 12).Value = "CBORE"
oCells.Item(1, 13).Value = "Under Class Approval"
oCells.Item(1, 14).Value = "Mass"
' Set all of the columns to autofit
'ExcelApp.Columns.AutoFit
' Save the file
'oWB.SaveAs (myXLS_File)
' Close the workbook and the Excel Application
' Uncomment if you want to close the xls file at the end
'oWB.Close
'ExcelApp.Quit
'ExcelApp = Nothing'
sw.WriteLine
sw.WriteLine
sw.WriteLine("Parts - " & DictionaryPartsPublish.count & "x")
sw.WriteLine
Dim j As Integer
For Each pair As KeyValuePair(Of String, Document) In DictionaryPartsPublish
sw.WriteLine(pair.Key)
DictionaryAllFilesToBePublished.add(pair.Key, pair.Value)
DictionaryAllFilesToBePublishedNoQTY.add(Left(pair.Key, InStrRev(pair.Key, "(") -1),Left(pair.Key, InStrRev(pair.Key, "(") -1))
'IsFileInUse(pair.Key)
' Fill the created Excel file
Dim oDoc As Document = pair.Value
' Get Properties
Dim sPartNumber As String = GetProp(oDoc, "DTP", "Part Number")
Dim sRev As String = GetProp(oDoc, "ISI", "Revision Number")
Dim sDescription As String = GetProp(oDoc, "DTP", "Description")
Dim sMaterial As String = GetProp(oDoc, "DTP", "Material")
Dim sThickness As String = GetProp(oDoc, "IUDP", "Thickness")
Dim sFinishing As String = GetProp(oDoc, "IUDP", "Finishing")
Dim sFabrication As String = GetProp(oDoc, "IUDP", "Fabrication")
Dim sBends As String = GetProp(oDoc, "IUDP", "Bends")
Dim sTAPPING As String = GetProp(oDoc, "IUDP", "TAPPING")
Dim sCSINK As String = GetProp(oDoc, "IUDP", "CSINK")
Dim sCBORE As String = GetProp(oDoc, "IUDP", "CBORE")
Dim sUnderClassApproval As String = GetProp(oDoc, "IUDP", "Under Class Approval")
Dim sPartParameters As String = GetProp(oDoc, "IUDP", "PartParameters")
Dim sMass As String = GetProp(oDoc, "IUDP", "Mass")
Dim sCombinedProductionOutput As String = GetProp(oDoc, "IUDP", "Combined Production Output")
sDocType = GetDocumentType_And_SubType(oDoc)
'Get Fabrication_info Flat, Bend or Unknown
If sFabrication Like "*F*" And sDocType Like "*Sheet_metal*" Then
sFabrication_Info = " " & sThickness & " mm Flat"
ElseIf sFabrication Like "*B*" And sDocType Like "*Sheet_metal*" Then
sFabrication_Info = " " & sThickness & " mm Bend"
Else
sFabrication_Info = ""
End If
' Make 'S', 'Z', Tapping, CSINK and CBORE visible
If sTAPPING Like "*Yes*" Or sCSINK Like "*Yes*" Or sCBORE Like "*Yes*" Or sFabrication Like "*S*" Or sFabrication Like "*Z*" Then
sFabrication_Info = sFabrication_Info & "+"
End If
' Add Picture
Dim oThumb As stdole.IPictureDisp
Do
oThumb = oDoc.Thumbnail
Loop While oThumb.Handle<0
Dim myPict As New AxHostConverter
Dim oImage As System.Drawing.Image=myPict.GetImageFromIPictureDisp(oThumb)
oImage.Save("C:\TEMP\bmptest.bmp",System.Drawing.Imaging.ImageFormat.Bmp)
'oCells.Item(j + 2, 1).Value = oImage
'Dim tempDoc As Document = pair.Key
'' ' Get the thumbnail image.
' Dim thumbnail As IPictureDisp 'stdole.IPictureDisp
' thumbnail = tempDoc.Thumbnail()
'' ' Convert the IPictureDisp object to an Image.
' 'Dim img As Image = Compatibility.VB6.IPictureDispToImage(thumbnail)
' 'Dim img As Image = pair.Value(thumbnail)
' 'Document.Thumbnail() As IPictureDisp
' 'oCells.Item(j + 2, 1).Value = GetProp(pair.Value, "ISI", "Thumbnail")
' 'oCells.Item(j + 2, 1).Value = img
' Try to add a picture to Excel
'xlWorkSheet.Shapes.AddPicture("C:\xl_pic.JPG", Microsoft.Office.Core.MsoTriState.msoFalse, Microsoft.Office.Core.MsoTriState.msoCTrue, 50, 50, 300, 45)
'r = oExcelSheet.Cells(5, 2)
'fileName = "C:\Workingfolder\Projecten\149.0389-PO\70\06-Parts-SS\AISI 304+\AISI 304+ A02095-389.ipt-A Bushing rope pulley Øh17 L=32mm(1x).jpg"
'pictureWidth = 195
'pictureHeight = 102
'shape = oExcelSheet.Shapes.AddPicture(fileName, Microsoft.Office.Core.MsoTriState.msoTrue, Microsoft.Office.Core.MsoTriState.msoTrue, r.Left, r.Top, pictureWidth * 3 / 4, pictureHeight * 3 / 4)
'oExcelSheet.Shapes.AddPicture(fileName, Microsoft.Office.Core.MsoTriState.msoTrue, Microsoft.Office.Core.MsoTriState.msoTrue, i + 2, j + 1, 100, 100)
'shape.LockAspectRatio = msoTrue
'shape.ScaleHeight 2, msoTrue, msoScaleFromTopLeft
Try
'oExcelSheet.Range("a1").Select()
'oExcelSheet.Rows(j + 2).select
'oExcelSheet.Columns(1).select
'oExcelSheet.Pictures.Insert(fileName)
' With ExcelApp.oExcelSheet.Pictures.Insert(fileName)
' With .ShapeRange
' .Width = 75
' .Height = 100
' End With
' .Placement = 1
' End With
' With oExcelSheet.Pictures.Insert(fileName:=imageFileName, LinkToFile:=msoTrue, SaveWithDocument:=msoTrue)
' With .ShapeRange
' .Width = destRange.Width
' .height = destRange.height '222
' End With
' .Left = destRange.Left
' .Top = destRange.Top
' .Placement = 1
' .Name = imageName
' End With
' ActiveSheet.Pictures.Insert(fileName).Select
' Selection.Top = Target.Offset(0, 2).Top
' Selection.Left = Target.Offset(0, 3).Left
' Selection.ShapeRange.LockAspectRatio = msoFalse
' Selection.ShapeRange.Height = Target.Offset(0, 2).Height
' Selection.ShapeRange.Width = Target.Offset(0, 3).Width
Catch ex As IOException
log.Close()
End Try
oCells.Item(j + 2, 2).Value = GetQTYfromStr(pair.Key)
oCells.Item(j + 2, 3).Value = sMaterial & sFabrication_Info
oCells.Item(j + 2, 4).Value = sPartNumber
oCells.Item(j + 2, 5).Value = sRev
oCells.Item(j + 2, 6).Value = sDescription
oCells.Item(j + 2, 7).Value = sFinishing
oCells.Item(j + 2, 8).Value = sPartParameters
oCells.Item(j + 2, 9).Value = sBends
oCells.Item(j + 2, 10).Value = sTAPPING
oCells.Item(j + 2, 11).Value = sCSINK
oCells.Item(j + 2, 12).Value = sCBORE
oCells.Item(j + 2, 13).Value = sUnderClassApproval
oCells.Item(j + 2, 14).Value = sMass
j = j + 1
Next
' Arrange Rows and Columns
' Those next lines seems to work
' Get Last Row and Last Column as numbers
With oExcelSheet
If ExcelApp.WorksheetFunction.CountA(.Cells) <> 0 Then
lRow = .Cells.Find(What:="*", _
After:=.Range("A1"), _
LookAt:=Excel.XlLookAt.xlPart, _
LookIn:=Excel.XlFindLookIn.xlFormulas, _
SearchOrder:=Excel.XlSearchOrder.xlByRows, _
SearchDirection:=Excel.XlSearchDirection.xlPrevious, _
MatchCase:=False).Row
Else
lRow = 1
End If
End With
With oExcelSheet
lCol = .Cells.Find(What:="*", _
SearchOrder:=Excel.XlSearchOrder.xlByColumns, _
MatchCase:=False).Column
Else
lCol = 1
End If
End With
' 'MessageBox.Show("LRow: " & LRow & vbNewLine & "LCol: " & LCol)
' ' Filter BOM for Normal or Purchased BOM_structure files
' 'Filter(oExcelSheet, Normal, lrRow)
' ' This resizes the selection but, I don't really know what for...
' Dim rng As Excel.Range
' 'rng = ExcelApp.Cells(1, 1).Resize(lRow, lCol)
' 'rng = oExcelSheet.Cells(1, 1).Resize(lRow, lCol)
' ' Create Table
oExcelSheet.ListObjects.Add()
oExcelSheet.ListObjects(1).Name = "Table"
' ' Set Table Style based on BoM Type
' ' HML Table Style :
' ' - Structured All Levels - Orange - TableStyleLight10
' ' - Structural Single Level - Black/White - TableStyleLight15
' ' - Parts Only Normal - Yellow - TableStyleLight10
' ' - Purchased - Blue - TableStyleLight12
' 'If BoMExporter = "Structured - All Levels" Then :oExcelSheet.ListObjects(1).TableStyle = "TableStyleLight10" : End If
' 'If BoMExporter = "Structured - Single Level" Then :oExcelSheet.ListObjects(1).TableStyle = "TableStyleLight15" : End If
' 'If BoMExporter = "Parts Only - (Shows components in a flat list)" Then : oExcelSheet.ListObjects(1).TableStyle = "TableStyleLight12" : End If
' ' If BoMExporter = "Purchased" Then : oExcelSheet.ListObjects(1).TableStyle = "TableStyleLight13" : End If
' ' Help
' ' xlCenter is a member of Microsoft.Office.Interop.Excel.Constants.
' ' Since you assigned Microsoft.Office.Interop.Excel To the name Excel, you can reference that constant Like this...
' ' oExcelSheet.Range("H15:H16").VerticalAlignment = Excel.Constants.xlCenter
'Freeze Header and Column
FreezeHeader(oExcelSheet, 1, 7)
'FreezeHeader(oExcelSheet, 1, 2)
' Autofit all Columns except the 1st one with pictures
oExcelSheet.Columns("B:" & GetExcelColumnName(LCol)).EntireColumn.AutoFit
' Center Columns Horizontaly
HorizontalAlignment_xlCenter(oExcelSheet, lCol, "QTY")
HorizontalAlignment_xlCenter(oExcelSheet, lCol, "REV")
HorizontalAlignment_xlCenter(oExcelSheet, lCol, "Fabrication")
HorizontalAlignment_xlCenter(oExcelSheet, lCol, "Bends")
HorizontalAlignment_xlCenter(oExcelSheet, lCol, "Tapping")
HorizontalAlignment_xlCenter(oExcelSheet, lCol, "CSINK")
HorizontalAlignment_xlCenter(oExcelSheet, lCol, "CBORE")
HorizontalAlignment_xlCenter(oExcelSheet, lCol, "Under Class Approval")
' ' Delete Columns
' 'DeleteColumn(oExcelSheet, lCol, "BOM Structure")
' 'DeleteColumn(oExcelSheet, lCol, "Stock Number")
' 'DeleteColumn(oExcelSheet, lCol, "Spare part")
' 'DeleteColumn(oExcelSheet, lCol, "Oem part number")
' 'DeleteColumn(oExcelSheet, lCol, "Maintenance")
' 'DeleteColumn(oExcelSheet, lCol, "Manufacturer")
' 'DeleteColumn(oExcelSheet, lCol, "Vendor")
' 'DeleteColumn(oExcelSheet, lCol, "Project")
' 'DeleteColumn(oExcelSheet, lCol, "Filename")
'oExcelSheet.Columns(1).ColumnWidth = 19
oExcelSheet.Rows.RowHeight = 68.25
oExcelSheet.Rows(1).RowHeight = 15
' ' Untill here above lines seems to work
' Save the file
oWB.Close
ExcelApp.Quit
ExcelApp = Nothing'
