Damian_Apex
338 Views, 3 Replies
Place assembly and display its form
I want a program that will add my assembly from a defined location and after placing it (this is working in my code), it will show me the form of newly added assembly.
I don't know if it's possible but it will be great if program will stop after this line:
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyPlaceComponentCmd").Execute
and after user will place it, form ("FORM1") will popup
Sub main
Dim Path As String = ThisDoc.Path & "\"
Dim AssyDoc As Document = ThisApplication.Documents.Open("D:\3_TEST\ACCESSDOOR\CUSTOM.iam", False)
ProjectNo = InputBox("Project Number", "iLogic", "000")
AssyDoc.SaveAs(Path & ProjectNo & "-ASSEMBLY-" & ".iam", False)
For Each oDoc In AssyDoc.AllReferencedDocuments 'loop through all part in assembly
	TAG_NO = InputBox("TAG", "iLogic", "001")
	oDoc.SaveAs(Path & ProjectNo & "item-" & TAG_NO & ".ipt", False)
Next
Dim oMatrix As Matrix
oMatrix = ThisApplication.TransientGeometry.CreateMatrix
Call oMatrix.SetTranslation(ThisApplication.TransientGeometry.CreateVector(50, 50, 50), True)
ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, AssyDoc.FullDocumentName)
ThisApplication.Documents.Open(AssyDoc.FullDocumentName, False)
Trace.Write(AssyDoc.FullDocumentName)
iLogicForm.Show("FORM1")
End Sub
