Michael.Navara
in reply to: karthur1
This question looks nice, but is very hard to implement. Because in some cases is not possible to interrupt  the execution. For example you can not interrupt execution inside transaction. More info.
You can implement the similar functionality using ProgressBar. See the following example
Sub Main
    Dim oSketetch As Sketch = ThisDoc.Document.ActivatedObject
    Dim linesCount = 1000
    DrawLinesInSketch(oSketetch, linesCount)
End Sub
Private progressBar As progressBar
Private cancelRequested As Boolean
Sub DrawLinesInSketch(oSketetch As Sketch, linesCount As Integer)
    'Initialze progress bar
    progressBar = ThisApplication.CreateProgressBar(False, linesCount, "Drawing lines", True)
    AddHandler progressBar.OnCancel, AddressOf ProgressBar_OnCancel
    'Draw lines to sketch
    For i As Integer = 1 To linesCount
        'Check if cancel opration is requested
        If cancelRequested Then
            Exit For
        End If
        progressBar.UpdateProgress()
        oSketetch.SketchLines.AddByTwoPoints(
        ThisApplication.TransientGeometry.CreatePoint2d(0, i),
        ThisApplication.TransientGeometry.CreatePoint2d(i, 0)
    Next
    'Cleanup progress bar
    RemoveHandler progressBar.OnCancel, AddressOf ProgressBar_OnCancel
    progressBar.Close()
    'Display final messageBox
        MsgBox("Canceled", MsgBoxStyle.Exclamation)
    Else
        MsgBox("Done", MsgBoxStyle.Information)
    End If
End Sub
Private Sub ProgressBar_OnCancel()
    cancelRequested = True
End Sub
For more complex task, which doesn't need Inventor for full time, you can use BackgroundWorker and use another thread for computing.
