tmathieson
in reply to: gcoombridge
thanks again!! i will give this a try, but in all likelihood will have to look at a different approach.  this is the 3rd time that i have tried to manipulate a component with model states thru an iLogic rule in an assembly where i have run into this problem.  in the other two cases, i ended up rewriting the code to take a different approach.  it seems like i will have to do the same thing here...
thanks again.  will let you know if this method works...
