tmathieson
in reply to: gcoombridge
Hi gcoombridge,
thanks so much for the reply.  it has helped, but still getting an error...so following your lead from above, i created these two lines of code to be sure my parameters exist and are correct...
MsgBox(Parameter(MakePath("SC-PRECAST:2", "SC-FOOTING - SIDE:1"),"TEST_5"))
MsgBox(Parameter(MakePath("SC-PRECAST:2", "SC-FOOTING - SIDE:1"),"SIDE_ANGLE"))
works fine!  windows pop up showing the values that exist in my component.  but... when i code like this, to pass the parameter from the assembly down to the component...
Parameter(MakePath("SC-PRECAST:2", "SC-FOOTING - SIDE:1"),"TEST_5") = ANGLE_SIDE
	Parameter(MakePath("SC-PRECAST:2", "SC-FOOTING - SIDE:1"),"SIDE_ANGLE") = ANGLE_SIDE
 i get....
Error in rule: FOOTING_UPDATE, in document: ASSEMBLY INSERT.iam
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
i should probably mention that both the sub and the component have model states....
could it be something to do with the units? i am just passing a number, no 'deg' or 'rad' or whatever...
thanks again!!
