gcoombridge
in reply to: tmathieson
@tmathieson brackets are wrong I think, they should enclose the makepath instructions as below:
msgbox(Parameter((MakePath("Test1:1", "Part1:1")),"Thickness"))
That way the path is a single object inside the parameter reference
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
