02-07-2022
05:31 AM
- Mute
- Permalink
- Report
02-07-2022
05:31 AM
Hello, I'm new to iLogic when it comes to drawings and I don't even know where to start with this one. So I'm hoping someone here can help! I'm using the following code to create a drawing reference list within the drawing. Is there a way to insert a custom part, a custom row within the DRL? Item No, Description, and Drawing are the 3 rows I'm using.
Thank you for your time!
Sub DRL() Dim oDrawingDoc As DrawingDocument oDrawingDoc = ThisApplication.ActiveDocument Dim oSheet As Sheet oSheet = oDrawingDoc.ActiveSheet ' Detect If the template has a parts list Try Dim oPartslistCheck As PartsList oPartslistCheck = oSheet.PartsLists(1) partslistpresent=True Catch partslistpresent=False End Try If partslistpresent=True 'Delete the current parts list Dim oPartsList As PartsList oPartsList = oDrawingDoc.ActiveSheet.PartsLists.Item(1) oPartsList.Delete End If ' a reference to the first drawing view on ' the sheet. This assumes the first drawing ' view on the sheet is not a draft view. Dim oDrawingView As DrawingView oDrawingView = oSheet.DrawingViews.Item(1) ' a reference to the sheet's border Dim oBorder As Border oBorder = oSheet.Border ' a reference to the sheet's title block Dim oTitleBlock As TitleBlock oTitleBlock = oSheet.TitleBlock ' '['Update BOM to Structured View ' InventorVb.DocumentUpdate() ' ' get model doc ' Dim oModelDoc As Document ' oModelDoc = ActiveSheet.View(oDrawingView.Name).ModelDocument ' ' get the BOM database ' oBOM = oModelDoc.ComponentDefinition.BOM ' ' Make sure the BOM view is enabled ' oBOM.StructuredViewEnabled = True ' ' Make sure the BOM first level is disabled ' oBOM.StructuredViewFirstLevelOnly = False ' ' the delimiter for the BOM view ' oBOM.StructuredViewDelimiter = "." ' oModelDoc.Rebuild2 ' oModelDoc.Save ' InventorVb.DocumentUpdate() ' '] '['Parts List Dim oPlacementPoint2 As Point2d xrev2 = oTitleBlock.RangeBox.MaxPoint.X - 0.62 yrev2 = oTitleBlock.RangeBox.MaxPoint.Y + 0.998 oPlacementPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(xrev2, yrev2) ' Create Parts List Dim oPartsList2 As PartsList oPartsList2 = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint2,PartsListLevelEnum.kStructuredAllLevels) '] InventorVb.DocumentUpdate() End Sub
