- Mute
- Permalink
- Report
Hello, I'm new to iLogic when it comes to drawings and I don't even know where to start with this one. So I'm hoping someone here can help! I'm using the following code to create a drawing reference list within the drawing. Is there a way to insert a custom part, a custom row within the DRL? Item No, Description, and Drawing are the 3 rows I'm using.
Thank you for your time!
Sub DRL() Dim oDrawingDoc As DrawingDocument oDrawingDoc = ThisApplication.ActiveDocument Dim oSheet As Sheet oSheet = oDrawingDoc.ActiveSheet ' Detect If the template has a parts list Try Dim oPartslistCheck As PartsList oPartslistCheck = oSheet.PartsLists(1) partslistpresent=True Catch partslistpresent=False End Try If partslistpresent=True 'Delete the current parts list Dim oPartsList As PartsList oPartsList = oDrawingDoc.ActiveSheet.PartsLists.Item(1) oPartsList.Delete End If ' a reference to the first drawing view on ' the sheet. This assumes the first drawing ' view on the sheet is not a draft view. Dim oDrawingView As DrawingView oDrawingView = oSheet.DrawingViews.Item(1) ' a reference to the sheet's border Dim oBorder As Border oBorder = oSheet.Border ' a reference to the sheet's title block Dim oTitleBlock As TitleBlock oTitleBlock = oSheet.TitleBlock ' '['Update BOM to Structured View ' InventorVb.DocumentUpdate() ' ' get model doc ' Dim oModelDoc As Document ' oModelDoc = ActiveSheet.View(oDrawingView.Name).ModelDocument ' ' get the BOM database ' oBOM = oModelDoc.ComponentDefinition.BOM ' ' Make sure the BOM view is enabled ' oBOM.StructuredViewEnabled = True ' ' Make sure the BOM first level is disabled ' oBOM.StructuredViewFirstLevelOnly = False ' ' the delimiter for the BOM view ' oBOM.StructuredViewDelimiter = "." ' oModelDoc.Rebuild2 ' oModelDoc.Save ' InventorVb.DocumentUpdate() ' '] '['Parts List Dim oPlacementPoint2 As Point2d xrev2 = oTitleBlock.RangeBox.MaxPoint.X - 0.62 yrev2 = oTitleBlock.RangeBox.MaxPoint.Y + 0.998 oPlacementPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(xrev2, yrev2) ' Create Parts List Dim oPartsList2 As PartsList oPartsList2 = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint2,PartsListLevelEnum.kStructuredAllLevels) '] InventorVb.DocumentUpdate() End Sub
- Mute
- Permalink
- Report
You will first need to loop through the partslist rows. See example here from API Help, the first for loop sets up a counter (i) which you can then index the row between 1 and the total number of parts list rows called the count. At a certain index number you can insert the custom row snippet. You may need to identify an item in your partslist like a description or part number etc and for that you may need the column for loop also to catch a specific cell.
The sample is vba so do a find and replace for Set and replace with blank and replace sub.... with sub main. It might be easier to simply work with the sample and then integrate into your version.
If you need help piecing it together just post the code your using and will be happy to help with advice.
Or if this helped you, please, click (like)
Regards
Alan
- Mute
- Permalink
- Report
