caroline_ccc
259 Views, 2 Replies
Rule to delete PFD object not working from assembly environment
Hello all.
I would like your help to understand the below. :smiling_face_with_smiling_eyes:
The below rule is included in one of my Inventor parts, it is used to delete a pdf file included as 3rd party object.
The rule works perfectly when I run inside the part environment, but when I request to run straight from the assembly  environment with ilogicVb.RunRule ("partABC", "Rule break link") it does nothing.
What would be the reason?
This is the rule included in the part file.
Dim oDoc As Inventor.Document
oDoc = ThisApplication.ActiveDocument
For Each ref As ReferencedOLEFileDescriptor In oDoc.ReferencedOLEFileDescriptors
If (iProperties.Value("Custom", "Material") = "ABC") And (iProperties.Value("Custom", "Type") = "X") Then
If (ref.DisplayName = "PDFA.pdf") Then
ref.Delete() 'delete reference
End if
End if
Next
Avoid to use ThisApplication.ActiveDocument Use ThisDoc.Document instead.
ThisDoc references to the document in which context the rule is running.
@Michael.Navara
Thanks for your fast reply and it works perfectly!
