A.Acheson
in reply to: hldr
The key to populating cells like your requesting  in excel is really where do you want to start and stop your input of data.
Because the range can be any size you need to try and find out what the size may be. You want to know where the last blank cell is in a specific column in many cases.
Here is a go excel method to achieve this.
GoExcel.Open(""C:\User\Desktop\" & test & ".xlsm"", "Parts List")
'Column Title
GoExcel.CellValue("K1") = "Mainassy"
GoExcel.CellValue("L1") = "assembly1"
GoExcel.CellValue("M1") = "Amount"
GoExcel.CellValue("N1") = "1"
For i = 2 To 1000  'Loop to a known row number past the populated data in the excel sheet
	Cellvalue = GoExcel.CellValue("A" & i+1) 'Check a known column with cells that are consistently populated like "Item" from a BOM List + 1 then to end on right row
	'Cell content
	GoExcel.CellValue("K"&i) = "Mainassy"
	GoExcel.CellValue("L"&i) = "assembly1"
	GoExcel.CellValue("M"&i) = "Amount"
	GoExcel.CellValue("N"&i) = "1"
	If Cellvalue = "" Then Exit For
Next
GoExcel.Save
GoExcel.Close
Here is another method using current region to find the table size, then find the last row then use autofill to populate data. You could also use a for loop like above to accomplish the same.
https://docs.microsoft.com/en-us/office/vba/api/excel.range.autofill
https://docs.microsoft.com/en-us/office/vba/api/excel.range.currentregion
'AddReference "Microsoft.Office.Interop.Excel.dll"
'Imports Microsoft.Office.Interop
'Imports Microsoft.Office.Interop.Excel
Sub Main()
Dim xlApp As New Excel.Application 'start a new instance of Excel
xlApp.DisplayAlerts = False
xlApp.Visible = True
Dim xlWorkbook As Workbook
xlWorkbook = xlApp.Workbooks.Open("C:\User\Desktop\" & test & ".xlsm")
Dim xlWorksheet As Worksheet
xlWorksheet = xlWorkbook.Worksheets.Item("Parts List")
'Column Title
xlWorksheet.Range("L1").Value = "assembly1"
xlWorksheet.Range("M1").Value = "Amount"
xlWorksheet.Range("N1").Value = "1"
Dim LastCol,LastRow As Long
LastCol = xlWorksheet.Range("A1").CurrentRegion.Columns.Count
LastRow = xlWorksheet.Range("A1").CurrentRegion.Rows.Count 'Find last row use any row that will have consistent content
'Cell content
xlWorksheet.Range("L2").Value = "assembly1"
xlWorksheet.Range("M2").Value = "Amount"
xlWorksheet.Range("N2").Value = "1"
'Cell Autofill
xlWorksheet.Range("L2").AutoFill(xlWorksheet.Range("L2:L" & LastRow))
xlWorksheet.Range("M2").AutoFill(xlWorksheet.Range("M2:M" & LastRow))
xlWorksheet.Range("N2").AutoFill(xlWorksheet.Range("N2:N" & LastRow))
xlWorkbook.Save
'xlWorkbook.Close (False)
'xlApp.Quit
End Sub
 I see that you are writing to a macro enabled work book so likely you can do the same within Excel VBA. I have a lot of Macros in my Macro workbook for processing BOM's and these are triggered by a population of a cell then the Excel VBA Macro takes over and finish the rest. It can be easier than converting the VBA macro to VB.NET.
Regards
Alan
