- Mute
- Permalink
- Report
Hi Samantha,
A template assembly or regular assembly would give you similar results I would think. Template assembly does nothing more than to create a new assembly.
Based on your new information and that of the initial post about future drawing automation I would think just performing a save as and look for a similar drawing name and save as and change file reference for the drawing would work for you. Alternatively perform a manual ilogic copy design/ design assistant copy and rename before you begin.
You may be better placing all files that are not changing into a library/read only folder to prevent unwanted changes happening. If a change is needed then perform a save and replace and the part can come to the project folder and is project specific at that point.
Hopefully that makes sense.
Or if this helped you, please, click (like)
Regards
Alan
