- Mute
- Permalink
- Report
The assembly model will a stand alone model. More than likely will not be inserted into a larger assembly but may need to be. Most of these designs are customer specific and that all they order. At times we do build the complete assembly for the customer where the hubs will be mounted. I do not need to rename the iParts as they will be from our standard drawing files. The Hub and Shaft will need to be renamed for specific customer number and hub description. My issue of confusion do I start this workflow from a assembly template or existing assembly file. I have the hub and shaft built with all the parameters named and is in stable condition for editing using ilogic. The iParts are built and are ready to build the assembly. We have a folder where all the iParts are located along with the different configuration of shaft to be used and controlled using iLogic.
Samantha
