- Mute
- Permalink
- Report
Sorry, I'm very new to iLogic and may not know all the terminology. I may not have explained my intentions clearly. What I want to do is to create an iAssembly, within that assembly I will have a hub, bearings, shaft, seals, and lock nut. The hub and shaft will be adjusted as per customer specs. I figure this is where iLogic and Forms come into play. I know iLogic should be able to control the bearing, seal and nut sizes from the iPart table. Also know iLogic can somehow create an assembly model with a new file name from the parameters given. Where I'm confused at, is do I start with an iAssembly file and rename it or do I start with a template with the assembly with constrained parts and iParts. I really don't have a full assembly model or code, as I have started over many times getting the parts stable for future use in the assembly.
Hope this clears things up a little bit.
Samantha
