02-03-2022
01:34 PM
- Mute
- Permalink
- Report
02-03-2022
01:34 PM
First things first. Is your starting base a regular assembly with iparts?
iAssembly is a fully configured table so ilogic would just switch the members, so you wouldnt be changing it on the fly with ilogic. Your title could be misleading. Could you show an image of the file structure and what your looking to change.
If these are all constant changes then an iassembly might be helpful but if there is custom assembly distances etc you may end up with just an ilogic controlled assembly controlling ipart/iassembly members.
Can you share the code your working with and some sample files? I will not be able to open them but other forum members might and can offer advice.
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
Regards
Alan
