swatkins3YWDA
1310 Views, 7 Replies
Create new Assembly from existing Assembly or Template and save as new file.
I'm having trouble getting started.  What I want to achieve is to start an assembly and use iLogic to change iPart  tables and save the model as a new assembly with specific file name and folder location.  I'm just a little confused where to begin.  Do I start with a template that has the assembly already built or do I start with an existing assembly model, which either would have to have a save as. I have managed to get the parameters to control the hub bore and shaft sizing.  Looking also to control the bearing component iPart table according to the hub bore ID and shaft OD.  I'm new to iLogic so a little confused getting started.    Also this work will have to be applied to many different hub styles and configurations.  Then eventually drawing automation for customer and shop drawings.  I just need help getting started and the drawing automation will be done later.
Thank for the help,
Samantha
Inventor 2022.2
