01-25-2022
06:05 AM
- Mute
- Permalink
- Report
01-25-2022
06:05 AM
Got this all up and running. Figured I'd post this here in case anyone else wanted the code. Also added the option to Sort and enable "autosortonupdate".
Public Sub PlacePartsList()
On Error Resume Next
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
'Set a reference to the active sheet.
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
' Set a reference to the first drawing view on
' the sheet. This assumes the first drawing
' view on the sheet is not a draft view.
Dim oDrawingView As DrawingView
Set oDrawingView = oSheet.DrawingViews(1)
' Set a reference to th sheet's border
Dim oBorder As Border
Set oBorder = oSheet.Border
Dim oPlacementPoint As Point2d
If Not oBorder Is Nothing Then
' A border exists. The placement point
' is the bottom-left corner of the border.
Set oPlacementPoint = oBorder.RangeBox.MinPoint
Else
' There is no border. The placement point
' is the bottom-left corner of the sheet.
Set oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
End If
' Create the parts list.
Dim oPartsList As PartsList
If oSheet.PartsLists.Count = 0 Then
Set oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint)
Else
Set oPartsList = oSheet.PartsLists.Item(1)
End If
Dim oPartsListSize As Vector2d
Set oPartsListSize = ThisApplication.TransientGeometry.CreateVector2d(0, 0)
oPartsListSize.X = oPartsList.RangeBox.MaxPoint.X - oPartsList.RangeBox.MinPoint.X
oPartsListSize.Y = oPartsList.RangeBox.MaxPoint.Y - oPartsList.RangeBox.MinPoint.Y
oPlacementPoint.X = oPlacementPoint.X + oPartsListSize.X
oPlacementPoint.Y = oPlacementPoint.Y + oPartsListSize.Y
oPartsList.Position = oPlacementPoint
'PartsList.Sort2( PrimaryColumnTitle As String, [PrimaryColumnAscending] As Boolean, [SecondaryColumnTitle] As String, [SecondaryColumnAscending] As Boolean, [TertiaryColumnTitle] As String, [TertiaryColumnAscending] As Boolean, [SortByString] As Boolean, [AutoSortOnUpdate] As Boolean )
Call oPartsList.Sort2("ITEM", True, "PART NUMBER", True, "QTY", True, True, True)
'Call oPartsList.Sort2("ITEM", True, AutoSortOnUpdate, True)
End Sub
