K.TRYFONIDIS
in reply to: WCrihfield
Thank you very much! We almost did it, i think it only needs some fine tuning now!
I had to put a temp variable because it didn't work without, i had an error message.
Only problem is that if i choose 4 or more options, only 3 appear in the box of iproperty ( did test for character limit but it seems there isnt one, at least short one, check image)
result.
test for character limit:
And a minor problem is that it shows (comma) , before first word also which seems awkward.. :face_with_tongue:
here is the code now.
Dim oTypes_Array As New ArrayList
oTypes_Array.Add("PRIONI")
oTypes_Array.Add("TRYPANI")
oTypes_Array.Add("TORNOS")
oTypes_Array.Add("MONTAZ")
oTypes_Array.Add("FREZA")
Dim oSelected As New ArrayList
While True
	oTypes_Selected = InputListBox("CHOOSE:", oTypes_Array, oTypes_Array(0), oRuleNo, X_oProp_Array)
	If String.IsNullOrEmpty(oTypes_Selected) Then Exit While
	oSelected.Add(oTypes_Selected)
End While
If oSelected.Count > 0 Then
	For Each oText In oSelected
		iProperties.Value("Custom", "NyfanRooting") = tempx
	tempx = iProperties.Value("Custom", "NyfanRooting") & ", " & oText
	next
End If
